Hello guys, I was wondering if my PSU 520 Watts Seasonic M12-II Evo is enough to handle the Gigabyte GTX 970 G1 Gaming, beacuse i visited their site and i saw this
"Recommended system power supply requirement: 550W(with one 6-pin and one 8-pin external power connectors)" its weird
https://linustechtips.com/topic/955194-gtx-970-power-needed/
It's almost certainly more than enough for it. More often than not the power requirement on the site is always a good bit more than what is actually needed because they don't know if you're running some dual core Celeron or a monster power whore HEDT chip.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/955194-gtx-970-power-needed/#findComment-11602330
Alright, so theres no problem on it?
https://linustechtips.com/topic/955194-gtx-970-power-needed/#findComment-11602341
1 minute ago, wONKEyeYEs said:
Now these measurements would increase with CPU OCing but generally
thing look good.
"Measured power consumption GTX 970
System in IDLE = 120 Watts
System Wattage with GPU in FULL Stress = 280 Watts
Difference (GPU load) = 160 Watts
Add average IDLE wattage ~10 Watts
Subjective obtained GPU power consumption = ~ 170 Watts
Mind you, the system wattage is measured at the wall socket side and there are other variables like PSU power efficiency. So this is an estimated value, albeit a very good one. "
https://www.guru3d.com/articles-pages/gigabyte-geforce-gtx-970-g1-gaming-review,7.html
I don't get over 430W on my main system with a GTX 980 and i7 6700k.
thanks! i thought i need to buy another PSU lol
https://linustechtips.com/topic/955194-gtx-970-power-needed/#findComment-11602349
NVIDIA recommends a minimum of 500W, higher than that is more than enough.
I've been wondering that as well, maybe it's for a headroom. I'm running GTX 970 (MSI) on a 500W PSU.
Where I hang out: The Garage - Car Enthusiast Club
My cars: 2006 Mazda RX-8 (MT) | 2014 Mazda 6 (AT) | 2009 Honda Jazz (AT)
PC Specs
Indonesia
CPU: i5-4690 | Motherboard: MSI B85-G43 | Memory: Corsair Vengeance 2x4GB | Power Supply: Corsair CX500 | Video Card: MSI GTX 970
Storage: Kingston V300 120GB & WD Blue 1TB | Network Card: ASUS PCE-AC56 | Peripherals: Microsoft Wired 600 & Logitech G29 + Shifter
Australia
CPU: Ryzen 3 2200G | Motherboard: MSI - B450 Tomahawk | Memory: Mushkin - 8GB (1 x 8GB) | Storage: Mushkin 250GB & Western Digital - Caviar Blue 1TB
Video Card: GIGABYTE - RX 580 8GB | Case: Corsair - 100R ATX Mid Tower | Power Supply: Avolv 550W 80+ Gold
https://linustechtips.com/topic/955194-gtx-970-power-needed/#findComment-11602353
So long as you're not running a 7980XE at retard-speed, I'm pretty confident in saying that you're golden.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/955194-gtx-970-power-needed/#findComment-11602354
cool thanks!
im not xD im gonna upgrade an i5 8400 soon
https://linustechtips.com/topic/955194-gtx-970-power-needed/#findComment-11602361
