Hello you fellow planners :) I have an extra hdd and it is not in a very good shape anymore, but i would like to use it as a secondary backup disk. It has about 60 reallocated sectors so it is not fun to start it up every time i turn on my pc.
Would it be possible to make a hardware power switch to the sata power cable so I could turn the drive off always when i dont need it. I know it would be easier to make it an external drive but internal are more handy to me :). The problem is that Sata power has so many cables, so i am not sure if a switch would be possible...
And not sure if this was the right thread, sorry.
Thanks
|OscillosC Build|+ Raspberry Pi [NAS] + Another G5 + Personal + HTPC: Asus Z87-A - Intel Core i5 4670K @ 4.5ghz 1.15v - Noctua NH-D14 - Gigabyte Radeon HD7870 OC @ 1170mhz core- Kingston HyperX 8gb 1600mhz CL9 - Samsung 840 PRO 128Gb SSD for Windows- Kingston V300 120gb for Ubuntu- WD Caviar Black 1Tb For games and programs - WD Caviar Green 2Tb For videos, photos, music, and backups- Seasonic P660 XP2 Platinum - Windows 8.1 PRO - Ubuntu 14.04 - Modded Bitfenix Ghost
https://linustechtips.com/topic/95483-hdd-power-switch-possible/
If you can set the drive to hotswap, sure.
https://linustechtips.com/topic/95483-hdd-power-switch-possible/#findComment-1280113
I can set it to hotswap but i just dont know which of the power cables should have the switch :)
https://linustechtips.com/topic/95483-hdd-power-switch-possible/#findComment-1281693
...Figure it out? Just look at which cable connects to your hdd.
https://linustechtips.com/topic/95483-hdd-power-switch-possible/#findComment-1281725
http://en.wikipedia.org/wiki/Serial_ATA Has some info on the Sata power connector pins.
You may however be better off looking at getting a new drive though as a drive that cant be on all the time is a drive I don't trust especially for backups. If you think about it you will only be putting backups on there every now and then not really enough time to detect a serious issue but let me tell you you will find the issue when you try to get that really important file off of there.
Star Citizen LTT Conglomerate Wants you! Join now!
UOLTT Basop | Misc Freelancer & Origin M50
Outside of a dog, a book is a man's best friend. Inside of a dog it's too dark to read.
-Groucho Marx
https://linustechtips.com/topic/95483-hdd-power-switch-possible/#findComment-1281744
Well, i am very well aware which cable goes to the hdd but sata power has four cables in it, so which cable of THOSE four is the one to cut and make a switch so that the drive stops and has NO power at all. But... maybe i just leave this.
https://linustechtips.com/topic/95483-hdd-power-switch-possible/#findComment-1282123
Yeah maybe :D The drive had been in active use for 4 years now and had no issues in normal work but only if i check S.M.A.R.T i notice the problems. And yes i would do a backup there about 6 times a year or so. Maybe this isnt worth it tho... Maybe i just put it in an external case as i have one laying.
https://linustechtips.com/topic/95483-hdd-power-switch-possible/#findComment-1282147
