Hello to anyone here, I was ordering parts for my pc when I recognized that the Asrock B350 Mobo seems to have a lot of issues with freezing and bios from the reviews given are these true and if so is their a better alternative here’s my part list for reference
PCPartPicker part list: https://pcpartpicker.com/list/W6L7pG
Price breakdown by merchant: https://pcpartpicker.com/list/W6L7pG/by_merchant/
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($149.99 @ Walmart)
Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard  ($49.99 @ Newegg)
Memory: Team - Vulcan 8GB (2 x 4GB) DDR4-3000 Memory  ($90.98 @ Newegg)
Storage: Kingston - A400 120GB 2.5" Solid State Drive  ($27.99 @ Amazon)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($43.40 @ OutletPC)
Video Card: Sapphire - Radeon RX 580 8GB NITRO+ Video Card  ($254.98 @ Newegg)
Case: Thermaltake - Versa H18 Tempered Glass MicroATX Mini Tower Case  ($47.99 @ SuperBiiz)
Power Supply: SeaSonic - 520W 80+ Bronze Certified Fully-Modular ATX Power Supply  ($49.99 @ SuperBiiz)
Monitor: AOC - G2460PF 24.0" 1920x1080 144Hz Monitor  ($199.56 @ Amazon)
Keyboard: EagleTec - KG010 Wired Gaming Keyboard  ($38.99 @ Amazon)
Mouse: Redragon - COBRA M711 Wired Optical Mouse  ($16.88 @ Amazon)
Headphones: Kingston - HyperX Cloud II 7.1 Channel  Headset  ($92.00 @ Newegg Marketplace)
Total: $1062.74
Generated by PCPartPicker 2018-07-30 19:38 EDT-0400
https://linustechtips.com/topic/954163-asrock-b350-pro/
The only thing i can say from experince is when i upgraded to ryzen i went with the asrock b350 it lasted the windows install and then got stuck in a boot loop i sent the board back to newegg and bought a asus prime plus b350 been running great for months now. And with the latest bios i can run my non xmp ddr4 2133 at 3200 with out issue.
what i have read on the net the asrock board does have the weakest vrm's of the b350's so if you plan to oc at you might want to look at other boards.
https://linustechtips.com/topic/954163-asrock-b350-pro/#findComment-11593585
