Posted July 30, 2018 This is my first time ever building a PC and for the past few weeks I have been looking at parts to put in it. I need help seeing if I missed any parts or the ones I chose are not compatible with each other. Yes I know there Is no graphics card but I plan on using the vega 11 graphics until the graphics card market stabilizes. Here are the links to the parts that I am looking at. Case: https://www.amazon.com/dp/B074VN8HNM/ref=twister_B07F471FVD?_encoding=UTF8&th=1 CPU: https://www.amazon.com/gp/product/B079D8FD28/ref=as_li_tl?ie=UTF8&tag=scattervoltyt-20&camp=1789&creative=9325&linkCode=as2&creativeASIN=B079D8FD28&linkId=7386b98887813630e446a12b29f7ec95 Motherboard: https://www.amazon.com/ASUS-Prime-B350-Plus-Ryzen-Motherboard/dp/B06X416NJ1 Ram: https://www.amazon.com/G-SKILL-TridentZ-16GB-25600-F4-3200C16D-16GTZR/dp/B01MTDEYHU/ref=sr_1_2?s=electronics&ie=UTF8&qid=1532913898&sr=1-2&keywords=rgb+ram&refinements=p_n_feature_five_browse-bin%3A677427011 Power Supply: https://www.amazon.com/dp/B074ZR8D6P/?SubscriptionId=AKIAJCMZ7EUWHXU3XRZQ&tag=cmcalc-20&linkCode=xm2 SSD: https://www.amazon.com/SanDisk-480GB-Solid-State-SDSSDA-480G-G26/dp/B01F9G43WU/ref=sr_1_4?s=electronics&ie=UTF8&qid=1532917498&sr=1-4&keywords=ssd&th=1 CPU Cooler: https://www.amazon.com/dp/B06VWX2QLT/ref=twister_B07D3NPQ1V?_encoding=UTF8&psc=1 FOOTNOTES I plan on splitting the ram with my moms computer and I know the power supply is slightly overkill. I also did not include the case fans for obvious reasons. Link to comment https://linustechtips.com/topic/954067-first-pc-build-please-help/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 30, 2018 Make a PCPartPicker list CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones Link to comment https://linustechtips.com/topic/954067-first-pc-build-please-help/#findComment-11592055 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 30, 2018 1 minute ago, r2724r16 said: Make a PCPartPicker list Yes please. Also what is your budget? So I can make a list for you. The graphics card market is as stable as it will ever be for the time being, with GPUs being at a all time low/ (Back to MSRP basically) Please quote me or @ me in your response so I get a notification. I really really really really like small text. Occupation: Gamer | Hours: 24/7 Full-Time | Hourly Pay: 0 | Benefits: Chick Magnet FINISHED BUILD - VIEW PROFILE If you say I'm not always right, but I am, I will say I am right. rekt Link to comment https://linustechtips.com/topic/954067-first-pc-build-please-help/#findComment-11592069 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 30, 2018 Author sorry I didn't think about that r2724r16 Here you go Case: CORSAIR CARBIDE SPEC-04 Mid-Tower Gaming Case CPU: AMD Ryzen 5 2400G Processor with Radeon RX Vega 11 Graphics Motherboard:ASUS Prime B350-Plus AMD Ryzen AM4 DDR4 ram: G.SKILL TridentZ RGB Series 16GB Power Supply: Cooler Master MWE 600 Watt 80 Plus Bronze SSD: SanDisk SSD PLUS 240GB CPU Cooler: Cooler Master RR-212TR-16PR-R1 Hyper 212 LED Turbo Link to comment https://linustechtips.com/topic/954067-first-pc-build-please-help/#findComment-11592096 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 30, 2018 Author MrShinny my budget is under 650 ish dollars but it can change a little bit. Also by saying when the market stabilizes I also meant when I could find a good deal on a graphics card. do you know of any decent budget graphics cards? I plan on playing fortnight occasionally but don't care too much about graphics I can play on low settings if I have to. Link to comment https://linustechtips.com/topic/954067-first-pc-build-please-help/#findComment-11592117 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 30, 2018 19 minutes ago, Nstud said: MrShinny my budget is under 650 ish dollars but it can change a little bit. Also by saying when the market stabilizes I also meant when I could find a good deal on a graphics card. do you know of any decent budget graphics cards? I plan on playing fortnight occasionally but don't care too much about graphics I can play on low settings if I have to. what games are you trying to play other than fortnite? I would spend a tad more money and find an older generation card like the nvidia gtx 950 or gtx 970. Since you are going ryzen the radeon rx 560,570,and 580 are cheaper graphics cards than the nvidia gtx line Also the Ryzen 5 2600 is $10 more than the ryzen 5 2400 on amazon https://www.amazon.com/dp/B07B41WS48/ref=sspa_dk_detail_1?psc=1&pd_rd_i=B07B41WS48&pd_rd_wg=aoRSB&pd_rd_r=68PSXPYYV6JFBBV71E9X&pd_rd_w=NwZRJ Link to comment https://linustechtips.com/topic/954067-first-pc-build-please-help/#findComment-11592184 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 30, 2018 17 minutes ago, Nstud said: MrShinny my budget is under 650 ish dollars but it can change a little bit. Also by saying when the market stabilizes I also meant when I could find a good deal on a graphics card. do you know of any decent budget graphics cards? I plan on playing fortnight occasionally but don't care too much about graphics I can play on low settings if I have to. a very nice low budget card, if going discrete graphics, is the 1050Ti 4GB cards, they are better than you might think My Gaming PC: 27833 Link to comment https://linustechtips.com/topic/954067-first-pc-build-please-help/#findComment-11592186 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 30, 2018 i would go with a second hand card off of ebay or something. I have had very good luck buying/selling gpu's on ebay. There's only speculation at this point at to when, but once nvidia announces their new gen of graphics cards, the 10 series will drop drastically in price. If you can't find something within your budget, it may be a good idea to wait Link to comment https://linustechtips.com/topic/954067-first-pc-build-please-help/#findComment-11592196 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 30, 2018 just threw something together for under 650, less rgb, fast ram, good psu and a 1050ti PCPartPicker part list / Price breakdown by merchant CPU: AMD - Ryzen 5 2400G 3.6GHz Quad-Core Processor ($154.89 @ OutletPC)Motherboard: ASRock - AB350M Micro ATX AM4 Motherboard ($54.89 @ OutletPC)Memory: G.Skill - Ripjaws V Series 8GB (2 x 4GB) DDR4-3000 Memory ($89.99 @ Newegg)Storage: Patriot - Burst 240GB 2.5" Solid State Drive ($44.99 @ Amazon)Video Card: MSI - GeForce GTX 1050 Ti 4GB Video Card ($164.99 @ Amazon)Case: Fractal Design - Define Mini C TG MicroATX Mid Tower Case ($59.99 @ SuperBiiz)Power Supply: Corsair - CX (2017) 550W 80+ Bronze Certified ATX Power Supply ($49.89 @ OutletPC)Total: $619.63Prices include shipping, taxes, and discounts when availableGenerated by PCPartPicker 2018-07-30 15:54 EDT-0400 would not recommend splitting a good set of dual channel ram when we talk about memory hungry ryzen on a gaming machine, there will be a difference on running only on one leg. also, there is no such thing as overkill psu's, it doesn't exist actually now when i think about it, consider switching the 2400g for a 1600 or 1600x if you go for the 1050ti, more threads and more longevity before next upgrade My Gaming PC: 27833 Link to comment https://linustechtips.com/topic/954067-first-pc-build-please-help/#findComment-11592240 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
