so i went to a cyber cafe for a printout stored on my pendrive.
when i got back home, i plugged in the usb and tried moving some files to it, it says write protected.
i tried formatting it, but failed. Please help me. i dont mind loosing the data on it i just need to be able to use the pen drive
https://linustechtips.com/topic/953909-write-protected-usb-pls-help/
1 hour ago, ZeouLs said:
Check if any of the files you tried to move is set to "Read-Only". That is pretty common at least in my case so that's the first thing I check.
no... i even get the message saying the drive is write protected while formatting
Format the drive, if it formats then good else try on another PC.
If not, then it is probably semi-dead and read only mode allows you to copy any data before it fails permanently. Flash drives have this as a defense mechanism when they detect they are dying.
