Intel i7 7700HQ Stress Test with Aida64 (Questions)
1 minute ago, MrFriendism said:Thanks for the solid answer, This is one of the best explanations I have ever had. I have 2-3 things more to ask.
How can I limit my processor to go with 3400 (3.4 Ghz max for any number of cores and regardless of how many cores are active)?
Because right now, It can go to 3.8 (3800) and I want it to limit a bit to 3.4 for all so that it doesn't go as high as 90s temp.
The reason for doing so is because the lesser your temp. is the more your CPU's life is. I hope you might agree with it.
In intel extreme tuning utility, you should be able to change all of the turbo ratios to 34. That will prevent the chip going past that speed under any circumstance, but it may depend on what functionality your motherboard exposes.
However, it's worth noting that a this will have a negligible effect on your temperatures, but may have a noticeable effect on single threaded or "bursty" applications. The reason is, frequency is a purely linear increase in heat output. Your temperatures now are with all cores at 3400 and fully loaded. Three cores at 3500, two at 3600 or one at 3800 will all use less power, and generate less heat, than 4 cores at 3400.
Therefore, your maximum temperatures under combined CPU and GPU load are not going to change even if you change your turbo boost profiles - unless you dropped it below 3.4.
It's why the turbo boost system is designed this way - even if you were heavily thermally constrained, you may still be able to boost to 3.8ghz on one core, because that will still be less heat output than two or more cores, even if they are running at a slower speed. This is almost universally true across all speed bins, so making the above change is only going to hurt your performance without impacting your temperatures.
You are correct that higher temperatures result in a lower life for your processor, in general. However, that's why all processors have a maximum die temperature they can safely run at - Intel is basically promising that so long as the chip (7700HQ in your case) doesn't go over 100C, it will have no reduced lifespan. That's why even at 95C it's still turbo boosting to the maximum available amount, instead of slowing down the CPU base speed of 2.8GHz. The specific figure is called "Tjunction" on the Ark page, and when it reaches this temperature the CPU will automatically slow down to keep from exceeding it. Intel basically guarantees that with 45W of cooling, the CPU can reach and sustain 2.8GHz at 100C or less.
The only issue is that in laptops, the total cooling capacity of the heatsink is shared between many components that all generate heat, and so your temperatures, even though they are safe, will be higher when stressing more of your system at the same time.
