So my Dell has been hitting 60C+, and the CPU shuts down the computer at 67C. I was curious about getting a USB 80mm fan that I can change the speed of to help cool it down. And the quieter the better.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/95364-usb-80mm-fan/
where do you wanna put that fan? O.o
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/95364-usb-80mm-fan/#findComment-1277074
why a USB fan? It would be stuck at 5V anyways so it won't move much air.
Every little bit helps.
I don't know yet, but it's gonna have to be in the back, since it's one of the smaller ones.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/95364-usb-80mm-fan/#findComment-1277246
have you tried cleaning the dust out and reapplying thermal paste?
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
https://linustechtips.com/topic/95364-usb-80mm-fan/#findComment-1278496
Thing is dust-free and has some of the kick ass Noctua paste on it.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/95364-usb-80mm-fan/#findComment-1279619
Good stuff. In that case you probably need a extra fan. I just have a generic molex 80mm fans in the front of my dell where the floppy and optical drive used to be, because i swapped out the 2ghz celeron for a 2.53ghz p4, which makes quite a bit more heat. Depending on which dell you have you might even fit a 92mm fan.
Rig Specs:
https://linustechtips.com/topic/95364-usb-80mm-fan/#findComment-1279716
I have the small one that takes a regular size optical drive, so that won't really work.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/95364-usb-80mm-fan/#findComment-1279728
