So I started to get parts for my first computer, and my friend helped me out by giving me a 550 Watt power supply for my build. The PSU model is an OKIA-550ATX.
So my question, to get straight to the point, is: could I connect a 20-pin connector to a 24-pin motherboard?
If it helps, the motherboard I chose is a GIGABYTE GA-AB350M-DS3H.
https://linustechtips.com/topic/953458-need-help-on-psu-connector/
If it's part of the wire harness rather than an additional adapter from 20 pin to 24 pin, then it should be fine. Though the brand does sketch me out. Looks like one of those cheap feather weight pieces of crap
EDIT: Yes it is
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
power supply is not recommended for long term use. Good for now but clearly wasn't designed for your use case, and is probably on the old side. My advice is to replace it before it craps out and takes something good with it. Get a corsair CX or something.
Primary PC:
PSU tier list
How many watts do I need?
