So... what's the problem?
Want to know which mobo to get?
Choose whatever you need. Any more, you're wasting your money. Any less, and you don't get the features you need.
Only you know what you need to do with your computer, so nobody's really qualified to answer this question except for you.
chEcK iNsidE sPoilEr fOr a tREat!
https://linustechtips.com/topic/953412-fan-problems/#findComment-11586143
11 hours ago, wONKEyeYEs said:
The first pic shows a fan with screw holes on both intake and out.
But your pics seem to only have holes on the output side.
Is this what you mean?
The fan isn't same as in pic. I guess thats case fan? Its designed to be use on that case alone, so its purpose built. You can still use it, you just need to get long screws or result to zipties or similar.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/953412-fan-problems/#findComment-11587373
