Need help, first build :) thanks
1 hour ago, Sb2333 said:Hello everyone, this is my first time building a game/work pc so any help will be appreciated!!! (PS: I use a 34" 1440P ultrawide)
i'll be starting my build in September, and I've finished my list, but I do have a few questions.
1. I'm getting a Ryzen 5 2600, whats the ram speed I should be looking at? Can I buy a lower speed ram and oc it?
2. Ram prices are stupid high, should I get a 8gb stick just to get through for now? If so, is it a good idea to get 2X4 or just 1X8?
3. Do i need more fans for the NZXT case?
4. Is my 520W power supply enough?
5. I see people installing drivers after installing windows, what are those?
Dont have to answer everything, thanks guys.
PCPartPicker part list: https://ca.pcpartpicker.com/list/6zycRJ
Price breakdown by merchant: https://ca.pcpartpicker.com/list/6zycRJ/by_merchant/
CPU: AMD - Ryzen 5 2600 3.4GHz 6-Core Processor ($239.99 @ Memory Express)
Motherboard: MSI - B350 PC MATE ATX AM4 Motherboard ($103.99 @ Amazon Canada)
Memory: G.Skill - Aegis 16GB (2 x 8GB) DDR4-3000 Memory ($182.99 @ Newegg Canada)
Storage: Crucial - MX500 500GB 2.5" Solid State Drive ($128.99 @ Amazon Canada)
Video Card: EVGA - GeForce GTX 1070 8GB SC GAMING ACX 3.0 Black Edition Video Card ($569.99 @ Amazon Canada)
Case: NZXT - S340 (Black/Red) ATX Mid Tower Case ($88.99 @ Newegg Canada)
Power Supply: SeaSonic - 520W 80+ Bronze Certified Fully-Modular ATX Power Supply ($79.99 @ Newegg Canada)
Case Fan: Cooler Master - R4-S4S-10AK-GP 60.9 CFM 140mm Fan ($14.80 @ Newegg Canada)
Total: $1409.73
Generated by PCPartPicker 2018-07-28 03:32 EDT-0400
If your going for a Motherboard that has 4 slots for RAM then I'd go the 2x4 route for better performance over a single 8gb RAM stick at the same speed. For gaming you won't really need more than 16gb which is also good for even graphic design and video encoding at the lesser half of RAM demand, to be fair 4x4 would perform better than 2x8 or 1x16 for when you decide to upgrade (16gb is plenty for gaming and I'd say go one step up in RAM speeds from the default end of speeds say ddr4 at 2400MHz).
Next I would recommend a $60 1tb HDD if you don't have one already to pull with a 7200rpm (a hybrid drive may be found for similiar prices, like Western Digital which I've never had issues with)
Also I would say stay with the stock fans and cooler to see your performance perhaps you will like what you got going on.
Have you considered getting a Zotac GTX 1080 mini? Its practically the same price as a EVGA 1070 and is better than a 1070ti for about $560-600USD, from Amazon.
Also if you don't care about looks (which I don't aside from my case) you can save in that department with your RAM (I don't mind green sticks).
So all in all my recommendations if they apply in Canada as reasonable:
1. Two 4gb RAM sticks at 2400MHz
2. Stock Fans/Cooler (upgrade of necessary)
3. Zotac GTX 1080 (mini)
4. 1TB WD 7200RPM HDD (64mb cache or more)
5. Enermax PSUs
6. A cheapo small sized SSD as a pagefile (used off eBay)
7. A used CPU from a highly rated vender on eBay
My suggestions may save you upfront maybe $200, but I'm going off United States.
