Hard drive not showing up.
Go to solution Solved by Spotty,
37 minutes ago, floppy disk mayhem said:
I was able to partition the one that is 2 terabytes, but the other one that was 4, failed to partition. I booted windows back up to see if it worked, and sure enough it showed up as a 2 terabyte drive.
When you partitioned it, did you use MBR which has a limit of 2TB? Make sure you are using GPT instead.
I am just installing windows on a new PC with another hard drive besides the boot SSD, I have done this before, but forgot how to do it, how do I partition it so that I can have it show up as a drive?
Please don't argue with me, I am just trying to help, or be helped. (we are all humans right?)
https://linustechtips.com/topic/952346-hard-drive-not-showing-up/
It should show up as a drive regardless of partitioning, shouldn't it?
for some reason it doesn't show up as a drive!
In the BIOS, in Windows, or not at all?
I checked and it's not showing up in the bios! I tried re plugging it back in and restarting it.
Try different SATA ports.
I tried changing sata cables and ports, but nothing showed up in windows or the BIOS!
Drive might be dead. Will it detect in other systems(if you any available to test)?
Let me check with my computer.
I booted up the windows 10 installer from a flash drive, and it showed up! it showed up as 2 un-allocated spaces? I was able to partition the one that is 2 terabytes, but the other one that was 4, failed to partition. I booted windows back up to see if it worked, and sure enough it showed up as a 2 terabyte drive. is part of the drive broken? what has happened?
I'm honestly clueless, I've never heard of or encountered this kind of problem before.
I found this out a while ago, and fixed it by turning it to GPT. thanks anyway!
