Need a little info
uReqt
I am buying the HyperX Cloud II but there has been some bad verbal reviews I have had people tell me. They say that its not a good mic for ingame voice com's with games  like R6,Overwatch, COD, Rust and BR Games. I was wondering if this was true and that is this headset worth it. The Cloud II's are in my price range and seem pretty much perfect, the only thing Im worried about is the mic quality ingame. Can anyone who owns/used to own give me some incite.
Thanks
        Current PC
CPU: I5-7400
GPU: Gigabyte 1050Ti
RAM: Crucial DDR4 8GB 2133mhz
CASE: GameMax Falcon
MOBO: Prime B250M-A
                                       Peripherals
Mouse: Corsair Sabre
Keyboard: Corsair Strafe
Mic/headphone: Blue Yeti /w JVC HA-SR50X
Mouse Mat: Razer Goliathus
2 minutes ago, uReqt said:
All headset mics are trash
most of them sound good enough though.
Go for open headphones though, like the SIbera 200s
I wan't a stand mic (With the stand and all) but I'm unsure about it due to the USB and Jack. Do I need to get a USB one for the 7.1 Surround sound? Or am I just tripping cus I honestly don't have a single clue. Also the mixer is that a necessary part because again I do not know how to do it. @Streetguru any1 that helps much thx's
        Current PC
CPU: I5-7400
MOBO: Prime B250M-A
                                       Peripherals
@Zmax I don't know lol Im noob asf
        Current PC
CPU: I5-7400
MOBO: Prime B250M-A
                                       Peripherals
@Zmax is it Realtek High  def audio is that it?
        Current PC
CPU: I5-7400
MOBO: Prime B250M-A
                                       Peripherals
Did you buy your comp at a retail store -- BEST BUY....
That could be the drivers for sound on your Mother Board ( were the CPU is )
Headset/Headphone surround sound is all just BS, doesn't matter if it's USB or 3.5mm for most things.
@Zmax nope I build it over the duration of 2 years, as I'm 16. I brought a bundle on Amazon Mobo,Ram,CPU.
        Current PC
CPU: I5-7400
MOBO: Prime B250M-A
                                       Peripherals
I agree. On headphone, surround sound does not matter.
Just get a pair of Headset  ( mic and headphone )  in your price range. You can do a bit of research in YouTube for best sound quality.
I have a set of SteelSeries , Mic is ok not great but ok , headphone are fine
After researching I just went to the store and bought the one I like,
@Streetguru in that case what Mic and Stand do you suggest, my budget it 70 pounds for the mic and 20 for the stand. (Mic arm w/ clamp for desk)
        Current PC
CPU: I5-7400
MOBO: Prime B250M-A
                                       Peripherals
Not needed, headset mics will be fine for in game audio, especially if your motherboard has decent onboard audio, possibly with noise supression.
If you really want a USB Mic get a Samson GO Mic, just don't plug your headphones into it.
@Streetguru What about this Audio-Technica ATR2500
        Current PC
CPU: I5-7400
MOBO: Prime B250M-A
                                       Peripherals
If you get a Mic , you may ambient noise when using , door closing, fans ....
Make sure to get unidirectional mic, it will record only in one direction, not the whole room
Are you producing content for the internet regularly or having important business calls on your PC?
If no you don't need an $80 microphone.
@Streetguru I will be on 10 hour gaming voice chat, aswell as I will be streaming.
        Current PC
CPU: I5-7400
MOBO: Prime B250M-A
                                       Peripherals
Probably just start with the $30 ish Samson GO mic, Just throw a sock over it for wind resistance.
@Streetguru Yah see I''m going to be on cam do I really don't want a shitty looking mic, I was a full sized audio technica looking mic in which is decent for gaming and streaming. w/ arm
        Current PC
CPU: I5-7400
MOBO: Prime B250M-A
                                       Peripherals
That's dumb
@Streetguru Because I would rather spend my money on something which looks decent and sounds good, other then something which sounds good but has a sock over it and looks ugly?. Thats your opinion and I respect that but It's my money and I'd rather spend it on looks as well as performance.
        Current PC
CPU: I5-7400
MOBO: Prime B250M-A
                                       Peripherals
I can assure you that no one cares what kind of microphone you use. The GO mic is just the easiest to deal with should you want a USB Mic, can just put it onto your monitor potentially and it'll be fine.
Or get one of these
Thanks all for help I am no longer posting here and will go to researching.
        Current PC
CPU: I5-7400
MOBO: Prime B250M-A
                                       Peripherals
If you want to buy a higher end microphone buy a Yeti or AT 2020, but you really don't need one.
@Streetguru I am buying a yeti
        Current PC
CPU: I5-7400
MOBO: Prime B250M-A
                                       Peripherals
