Throttlestop issue
Go to solution Solved by unclewebb,
If you do not want ThrottleStop to minimize to the Task Bar then make sure that Task Bar is not checked on the main screen.
If Minimize on Close is checked, ThrottleStop will minimize if you click on the close gadget, (X) at top right of main screen.  I like having that one checked so I do not accidentally close ThrottleStop.  Better to leave it running.
Hey people!
So I've just learned to use ThrottleStop for my new Razer Blade 15, the only minor annoyance I have, is that I can't seem to be able to minimize it to system tray?
Whenever I minimize it, it just goes down to taskbar as a normal program, and yes I've already ticked in the settings "minimize on close" .
Any pros out there know whats going on?
https://linustechtips.com/topic/952099-throttlestop-issue/
Did you tick on that? If yes, uncheck it
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/952099-throttlestop-issue/#findComment-11573932
https://linustechtips.com/topic/952099-throttlestop-issue/#findComment-11575955
Yeah okay, I think what i meant is, I want only the notification icon, and not having it on taskbar, as when I have throttlestop opened, i can see it already has an icon in the notification area, and I only want that.
EDIT: Nevermind!I now know what u mean with main screen, thanks man :D
Edited by Joey96
figured it out
https://linustechtips.com/topic/952099-throttlestop-issue/#findComment-11576860
