hello
i need help because windows 10 takes op more than 50% of my ram. i have 8gb ddr4 ram in my pc and windows takes up 4gb or more.
my specs are:
CPU: amd ryzen 5 1500x
GPU: nvidia geforce gtx 1050 ti
mb: gigabyte GA-AB350M-Gaming 3
hdd: WD blue WD10EZEX 1TB
ssd: WD blue ssd 500GB
Ram: Team Group Elite TED48G2133C1501 8GB DDR4
PSU: Corsair VS450
https://linustechtips.com/topic/951576-ram-problems/
I may want to go to resource monitor and check what process using the most commit and working set, then analyze how many wait chains it's having. Learn if that's the master process or the elements of its tree. So you can be sure you're not killing any critical process but rather something that can be considered as PUMs (potentially unwanted malware).
console.log("way to pro");
https://linustechtips.com/topic/951576-ram-problems/#findComment-11568853
