Picking a Monitor for Upgrade
TraskJ
I'll be upgrading my GPU to a 1070ti sometime soon, and my current 1080p 75hz Freesync monitor won't be able to handle the power of the 1070ti. I'm planning to get a 1440p monitor, but will the 1070ti be able to push 144hz often enough to justify paying the premium for that? And if my GPU can push 144hz, do I even need to bother with GSync? I'd like to pay around $500 for my monitor, but I'm open to pricing options. Any recommendations are welcome. Thanks!
Everything I know I learned from the internet. Also school.
Current Desktop:
CPU: Ryzen 5 1600 @3.65 ghz, Cryorig H7
MoBo: Asus Prime X470-Pro
GPU: Gigabyte RTX 2060 Super OC
RAM: 2x8 gb Corsair Vengeance LPX DDR4 @2666mhz
PSU: 650W EVGA SuperNova
Storage: 120gb SK Hynix SSD, 240gb SanDisk SSD Plus, 1 TB 2015 WD Blue
Case: Corsair Carbide 100R
Peripherals: Logitech G Pro keyboard, Razer DeathAdder Elite, Logitech G305, Logitech G600, 24" AOC FreeSync 1080p monitor x2
You surely would be able to get 144hz, but at the sacrifice of quality so don’t expect to get 144hz at Ultra everything. As for Gsync, if you can find a monitor under your price range with it then you should probably get it. I can’t really recommend any monitor since I haven’t really looked to upgrade my VG248QE (144hz 1080p 1ms) so I can’t help ya there so good luck :D
Btw make sure to oc that 1070Ti lel
poop
That depends on what settings you want to play your games at. If you're wanting ultra-max settings, then no. The 1070 Ti won't even come close. Maybe one notch down or another below that will work.
No, but you should enable Fast Sync so you don't have tearing.
Yeah, I figured I'd get a good 1070ti and just OC it and basically have a 1080. I play Overwatch on mostly low settings to help with latency, so quality settings shouldn't be an issue.
Current Desktop:
I play Overwatch on low settings. Other games can stick with their 60 fps, that's fine by me. I have absolutely no idea what fast sync is. Time for me to start googling. Thanks!
Current Desktop:
When shopping around for a new monitor on Amazon last week, I stumbled upon the Dell S2417DG YNY1D. It's a 165Hz 1440p monitor with G-Sync that will run you about $400. Generally, G-Sync is not worth the money, but this is one of the more affordable monitors I came across. I don't own it, as I went for a $300 240hz Freesync on Prime Day, but most Amazon reviewers seem to be very happy with it.
Make sure to quote me or use @PorkishPig to notify me that you replied!
Desktop
CPU - Ryzen 9 3900X | Cooler - Noctua NH-D15 | Motherboard - ASUS TUF X570-PLUS RAM - Corsair Vengeance LPX DDR4-3200 32GB Case - Meshify C
GPU - RTX 3080 FE PSU - Straight Power 11 850W Platinum Storage - 980 PRO 1TB, 960 EVO 500GB, S31 1TB, MX500 500GB | OS - Windows 11 Pro
Homelab
CPU - Core i5-11400 | Cooler - Noctua NH-U12S | Motherboard - ASRock Z590M-ITX RAM - G.Skill Ripjaws V DDR4-3600 32GB (2x16)  | Case - Node 304
PSU - EVGA B3 650W | Storage - 860 EVO 256GB, Sabrent Rocket 4.0 1TB, WD Red 4TB (x6 in RAIDZ1 w/ LSI 9207-8i) | OS - TrueNAS Scale (Debian)
Oooh I like that one. I might actually go for the 27" version, but the bezels on the 24" are tempting. Thanks!
Current Desktop:
