What is it being used for? Gaming alone or other tasks?
https://linustechtips.com/topic/951324-building-first-pc/#findComment-11566638
3 minutes ago, Socratus said:
Ryzen 7 2700x , Rx 580/570, x470 mobo (most likely Asus Prime) for case im thinking Cooler Master Master Case 5 and a 750W psu (would bronze be good) also what ram would be good.
Also for gaming only I would go for the 2600x
MAIN BUILD!
https://linustechtips.com/topic/951324-building-first-pc/#findComment-11566647
Virtually any RAM that is at least 3000MHz will do for Ryzen.
As for PSU, corsair TX750M and CX750M models are good options, both being semi-modular and cable-management-friendly. Although having said, you probably don't need a 750W PSU unless you're going to something like a GTX 1080 Ti in the future.
mechanical keyboard switches aficionado & hi-fi audio enthusiast
switch reviews  how i lube mx-style keyboard switches
https://linustechtips.com/topic/951324-building-first-pc/#findComment-11566651
This site should help with that. in the upper right corner you can choose a country: https://uk.pcpartpicker.com/products/memory/#s=403000,403200&sort=price&page=1
that is the list of sticks that are 3000-3200MHZ.
There are boxes to allow you to choose whether 1x4, 2x4, 1x8, 2x8, etc. suggested 2xCapacity kits or matched 1xkits
Rawr.
https://linustechtips.com/topic/951324-building-first-pc/#findComment-11566654
If its for gaming, get a 2600 with a b350 Pro4 and put the extra $200 towards a vega 56 or gtx 1080.
For your PSU, go with a 650 from an upper mid-range line (focus+, TXM, RM...)
For RAM, the Ripjaws V 3600 is on sale for $155 right now, major no-brainer.
I edit the shit out of my posts.  Refresh before you respond.
https://linustechtips.com/topic/951324-building-first-pc/#findComment-11567268
