Disable the pad, turn off +48v (phantom power is only needed on condenser microphones), turn on direct monitoring, check your audio hardware settings in your DAW.
"Not breaking it or making it worse is key."
"Bad choices make good stories."
https://linustechtips.com/topic/951286-xlr-mic-problem/#findComment-11566290
