so i just bought everything i needed for this condenser mic i had and i wanted to use, and everything was smooth nothing was off the mic was fine the phantom power supply was on everything was working, except i try to go and use it to talk to some friends on discoed and it does not register my voice, so. i went to discord settings and saw that yes my mic was connected to be the mic i use to talk but it wasnt taking my voice and making it so my friends could hear me so then i went to the audio settings on windows 10 and i saw that my mic was working, it was just reeeeeaaalllyyy quiet ( like so quiet i think thats why discord wouldnt take the sound bc it probably tought it was background noise it was that low) and so i cranked up the input volume on discord and you still can cant hear my voice. is there anything i can do to bring up the volume so that u can actually hear my voice thru the mic? ( i know very little abuot microphones and this kinda stuff, like i know i have to talk into it and thats it. The mic i have is the Neewer NW-800 and the phantom power supply is the Neewer 1 channel 48v phantom power supply.
https://linustechtips.com/topic/951281-condenser-mic-issue/
You should be able to turn up a mic boost in windows sound settings.
https://linustechtips.com/topic/951281-condenser-mic-issue/#findComment-11566261
Condenser Mic's can get rather complicated rather fast, you can try to turn up the DB in windows sound settings and boost it to the max.
Any reason why you went Condenser instead of a USB mic?
Ryzen 9 3950x - 64 GB DDR4 - NVME 980 pro SSD - EVGA RTX 3080 FTW Ultra - FAD CASE
Full custom loop / links below out of date
LTT Build Log | PCPP Build Log
_____________________________________________________________________________________________
Sorry if I stop responding, I've probably gotten busy as I mostly am only on here while working.
https://linustechtips.com/topic/951281-condenser-mic-issue/#findComment-11566278
i ordered condensor not knowing it was condensonr , i did it a while back when i was barely getting into the tech world, and yeah i saw that the notch to turn up the db i tried and it wouldnt let me, and then it said that the mic had no jack connection for no reason. its plugged into the motherboard in the little red circle thing
it says there is no jack information when before it told me it was connected to the red mic spot on the motherboard
Edited by Leucon
https://linustechtips.com/topic/951281-condenser-mic-issue/#findComment-11566350
im sorry about the miss spelling i cant type
https://linustechtips.com/topic/951281-condenser-mic-issue/#findComment-11566355
