Can someone please explain to me what is the difference between a zybo board and a raspberry board?
I am trying to make an iris recognition program and i am using e-radu's program from istructables(https://www.instructables.com/id/Iris-recognition-on-Zybo/#discuss), but i cant make it run on my laptop without errors. IN his program he is using a zybo board while i am using just my laptop. Are the issues i am facing caused by the lack of a zybo board? and can i use a raspberry pi instead of a zybo board?
https://linustechtips.com/topic/951203-zybo-and-raspberry-pi/
They’re 2 different microcontroller devices. (Maybe more so credit Card Computers.)
I’d imagine Zybo to be “more powerful” but it really depends on what you’re doing.
It seems zybo is a full on tiny computer and the raspberry pi is a computer that acts like a microcontroller. I have programmed the arduino which is not a conputer but a device that can control electronics like a computer.
https://linustechtips.com/topic/951203-zybo-and-raspberry-pi/#findComment-11565710
so I can do whatever zybo can do on my laptop?
https://linustechtips.com/topic/951203-zybo-and-raspberry-pi/#findComment-11568508
What kind of problems are you having?
What errors are you getting?
What OS is your laptop running?
https://linustechtips.com/topic/951203-zybo-and-raspberry-pi/#findComment-11568558
I am using Kali Linux OS.
The output i am getting is something like this
RadS:  21, max:   13, pos:( 104,   65)
RadB:  47, max:   12, pos:(  79,    0)
RadB:  45, max:    8, pos:(  81,    0)
In his comments he stated that this output is the algorithm trying to draw circles to locate and extract the iris and can be resolved by SDL Library. I have installed SDL library but the error still persist.
This error prevents the program from creating a new user and adding an image to the database.
https://linustechtips.com/topic/951203-zybo-and-raspberry-pi/#findComment-11568571
To me that output looks just like debug data; which judging by the code will apparently be printed anyway.
If there were to be a problem with SDL library, the program wouldn't likely compile or run to begin with.
I failed to find any relevant comments by the author via the link you provided or in the repository itself, can you provide a link to them?
Does the window with the webcam data show up? Does it update? And is the correct stuff drawn over it?
https://linustechtips.com/topic/951203-zybo-and-raspberry-pi/#findComment-11568604
The webcam window shows up fine. The problem is when it comes to the correct stuff being drawn on the screen. I take it to mean that by the 'correct stuff' you mean that the circles to detect the eye and then the smaller circle to detect the iris. They are only visible when the eye is placed closer to the camera, but instead of printing "user not in database" it prints "segmentation done...matching done" on the terminal. Trying to add a user to the database results in the same issue as above, instead of "2 images added" i get "segmentation done ... matching done."
About the comments by the author, The author replied to a comment written by Eric w Clarkson, he had an error almost similar to mine. The only difference is that his was a SDL error with the many numbers being printed. That was the only comment the author wrote. Efforts to reach him have bore no fruits for the past month.
https://linustechtips.com/topic/951203-zybo-and-raspberry-pi/#findComment-11568650
Looks like the "matching done" text should only be printed when you haven't started the program with the 'a'-flag to put it into the ADD_IRIS mode.
So, what's the command you start the program with? It should be something like "./irisRec_v1 -a"
https://linustechtips.com/topic/951203-zybo-and-raspberry-pi/#findComment-11568666
yes,to add a user to the database i started the program with ./irisRec_v1 -d /dev/video0 -a "username"
and to check if one is in database i started it with .irisRec_v1 -d /dev/video0
https://linustechtips.com/topic/951203-zybo-and-raspberry-pi/#findComment-11568674
And you still get the "matching done" output when trying to add an user?
According to the code that shouldn't happen: https://github.com/e-radu/irisRec/blob/608e718464e3b7358cd72be5ba2dac1abc0ea542/irisTop.c#L155-L172
I'd recommend you to paste the entire output of a quick test run.
https://linustechtips.com/topic/951203-zybo-and-raspberry-pi/#findComment-11568680
result of ./irisRec_v1 -d /dev/video0 -a "username".
their is no matching done but i expected a text showing that an image has been added to the database.
 "RadB:  47, max:    8, pos:(  43,   85)
RadS:  16, max:    8, pos:(  47,   90)
RadB:  40, max:    6, pos:(  49,   84)
Segmentation done!
Segmentation done!
Drawing done!
Encoding done!
RadS:  18, max:    9, pos:(  67,  113)
RadB:  41, max:    6, pos:(  43,   89)
RadS:  19, max:   14, pos:(  48,   92)"
this is the result i get
https://linustechtips.com/topic/951203-zybo-and-raspberry-pi/#findComment-11568697
Segmentation done!
Segmentation done!
Drawing done!
Encoding done!
below the above results i get
Warming 10
RadS:  14, max:   13, pos:(  83,    0)
RadB:  39, max:    8, pos:(  38,   76)
Warming 9
RadS:  16, max:   10, pos:(  85,    0)
Warming 8
RadS:  14, max:   10, pos:(  83,    0)
RadB:  59, max:    7, pos:(  37,   56)
Warming 7
RadS:  15, max:   10, pos:(  84,    0)
RadB:  41, max:    7, pos:(  39,   73)
https://linustechtips.com/topic/951203-zybo-and-raspberry-pi/#findComment-11568698
Warming 10
Warming 9
Warming 8
Warming 7
The entire output is :
Opening device /dev/video0
Users in database: 0
Driver Caps:
  Driver: "uvcvideo"
  Card: "Integrated_Webcam_HD: Integrate"
  Bus: "usb-0000:00:14.0-5"
  Version: 1.0
  Capabilities: 84a00001
Camera Cropping:
  Bounds: 160x120+0+0
  Default: 160x120+0+0
  Aspect: 1/1
  FMT : CE Desc
  YUYV:    YUYV 4:2:2
  MJPG: C  Motion-JPEG
Selected Camera Mode:
  Width: 160
  Height: 120
  PixFmt: YUYV
  Field: 1
Length: 38400
Address: 0x7fd5faf15000
Image Length: 0
Warming 9
Warming 8
Warming 7
Warming 6
Warming 5
Warming 4
Warming 3
Warming 2
Warming 1
Warming 0
RadS:  10, max:    7, pos:( 109,    0)
RadB:  39, max:    8, pos:(  55,   99)
RadS:  26, max:    9, pos:(  62,   97)
RadB:  64, max:    8, pos:(  58,    0)
RadS:  25, max:    9, pos:(  29,   89)
RadB:  43, max:   10, pos:(  51,  111)
RadS:  20, max:   11, pos:(  30,   87)
RadB:  39, max:    7, pos:( 105,   88)
RadS:  10, max:    8, pos:( 109,    0)
RadB:  66, max:    8, pos:(   6,    0)
RadS:  19, max:    8, pos:(  29,   87)
RadB:  42, max:    7, pos:( 106,   80)
RadS:  20, max:    9, pos:(  97,   59)
RadB:  45, max:    7, pos:( 107,   75)
RadS:  24, max:   10, pos:(  35,   81)
RadB:  43, max:    7, pos:(  89,  158)
RadS:  18, max:   11, pos:(  89,  126)
RadB:  47, max:    6, pos:(  35,  105)
RadS:  15, max:   19, pos:(  99,  117)
RadB:  43, max:    8, pos:(  60,   59)
RadS:  20, max:   12, pos:(  98,   55)
RadB:  42, max:    6, pos:(  41,   90)
RadS:  37, max:    9, pos:(  39,   83)
RadB:  51, max:    8, pos:(  49,  139)
RadS:  27, max:   10, pos:(  35,   72)
RadB:  39, max:    6, pos:(  41,   37)
RadS:  23, max:    9, pos:(  34,   71)
RadB:  59, max:    8, pos:(  41,  136)
RadS:  24, max:   10, pos:(  34,   66)
RadB:  50, max:    6, pos:(  53,   24)
RadS:  27, max:    9, pos:(  35,   72)
RadB:  49, max:    7, pos:(  41,   48)
RadS:  27, max:   11, pos:(  34,   67)
RadB:  39, max:    6, pos:(  35,   78)
RadS:  24, max:   10, pos:(  36,   67)
RadB:  57, max:    7, pos:(  36,   95)
RadS:  25, max:    9, pos:(  36,   68)
RadB:  60, max:    7, pos:(  49,   97)
RadS:  26, max:    9, pos:(  33,   66)
RadB:  49, max:    7, pos:(  52,   23)
RadS:  30, max:   10, pos:(  37,   68)
RadB:  42, max:    7, pos:(  36,   79)
RadS:  26, max:   12, pos:(  34,   65)
RadB:  59, max:    7, pos:(  41,  135)
RadS:  24, max:   11, pos:(  37,   65)
RadB:  51, max:    8, pos:(  47,   47)
RadS:  21, max:   11, pos:(  34,   63)
RadB:  41, max:    7, pos:(  45,   23)
RadS:  14, max:    8, pos:( 112,    0)
RadB:  49, max:    7, pos:(  47,   49)
RadS:  20, max:   10, pos:(  33,   61)
RadB:  53, max:    7, pos:(  48,   45)
RadS:  23, max:   11, pos:(  36,   62)
RadB:  55, max:    8, pos:(  48,   43)
RadS:  24, max:   12, pos:(  37,   61)
RadB:  46, max:    7, pos:(  50,   15)
RadB:  39, max:    7, pos:(  49,   59)
RadS:  36, max:    9, pos:(  49,   62)
RadS:  23, max:   10, pos:(  36,   60)
RadB:  58, max:    8, pos:(  48,   40)
RadS:  21, max:    9, pos:( 105,   52)
RadB:  42, max:    9, pos:(  48,   56)
RadB:  40, max:    7, pos:(  35,  138)
RadS:  22, max:   11, pos:(  31,   61)
RadB:  63, max:    7, pos:(  35,   20)
RadS:  31, max:   10, pos:(  47,   67)
RadB:  53, max:   10, pos:(  48,   45)
RadS:  21, max:   11, pos:(  31,   63)
RadB:  39, max:    7, pos:(  37,    0)
RadS:  25, max:   13, pos:(  36,   66)
RadB:  64, max:    7, pos:(  47,   34)
RadS:  25, max:   11, pos:(  36,   67)
RadB:  43, max:   12, pos:(  48,   55)
RadS:  28, max:    9, pos:(  38,   70)
RadB:  39, max:    8, pos:(  48,   59)
RadS:  27, max:   10, pos:(  37,   70)
RadB:  58, max:    7, pos:(  48,   40)
RadS:  27, max:   12, pos:(  37,   70)
RadB:  43, max:    8, pos:(  48,   55)
RadS:  25, max:   10, pos:(  52,   70)
RadB:  45, max:    8, pos:(  48,   53)
RadB:  46, max:    7, pos:(  47,   52)
RadS:  26, max:   12, pos:(  37,   69)
RadB:  40, max:   10, pos:(  49,   58)
RadB:  45, max:   11, pos:(  48,   53)
RadS:  18, max:    9, pos:( 103,   54)
RadB:  64, max:    8, pos:(  47,   34)
RadS:  22, max:   11, pos:(  36,   65)
RadB:  39, max:    8, pos:(  49,   60)
RadS:  23, max:   10, pos:(  36,   66)
RadB:  42, max:   10, pos:(  48,   56)
RadS:  27, max:   16, pos:(  37,   70)
RadB:  39, max:    7, pos:(  48,   59)
RadS:  27, max:    9, pos:(  36,   71)
RadB:  58, max:   10, pos:(  48,   40)
RadS:  27, max:   10, pos:( 106,   58)
RadB:  48, max:   12, pos:(  48,   50)
RadS:  26, max:   10, pos:( 105,   57)
RadS:  25, max:    9, pos:(  32,   73)
RadB:  44, max:    9, pos:(  47,   54)
RadS:  23, max:   10, pos:( 102,   55)
RadB:  40, max:    6, pos:(  43,   34)
RadS:  22, max:   11, pos:( 101,   55)
RadB:  47, max:    6, pos:(  52,   21)
RadS:  20, max:   11, pos:(  33,   82)
RadB:  40, max:    6, pos:(   7,   27)
RadS:  22, max:   12, pos:(  34,   83)
RadB:  42, max:    6, pos:( 119,  102)
RadS:  22, max:    9, pos:(  34,   86)
RadB:  49, max:    7, pos:(  53,   22)
RadS:  16, max:    9, pos:(  94,   56)
RadB:  40, max:    7, pos:( 118,   75)
RadS:  10, max:   11, pos:( 119,   17)
RadB:  50, max:    8, pos:(  59,   15)
RadS:  23, max:   12, pos:(  34,   93)
RadB:  42, max:    8, pos:(  43,  110)
RadS:  11, max:   11, pos:( 109,   55)
RadB:  41, max:    8, pos:(  43,  111)
RadS:  20, max:   10, pos:(  34,  101)
RadB:  49, max:    9, pos:(  53,   22)
RadS:  35, max:   10, pos:(  80,    0)
RadS:  19, max:    9, pos:(  33,  106)
RadB:  48, max:    8, pos:(  42,  118)
RadS:  16, max:   10, pos:(  26,  104)
RadB:  53, max:    9, pos:(  59,   12)
RadS:  20, max:    9, pos:(  32,  106)
RadB:  48, max:    9, pos:(  51,   23)
RadS:  16, max:   10, pos:(  25,  104)
RadS:  30, max:   10, pos:(  69,    3)
RadB:  41, max:    7, pos:(  43,  111)
RadS:  15, max:    9, pos:(  64,   52)
RadB:  42, max:    8, pos:(  27,  107)
RadS:  10, max:    9, pos:(  69,   73)
RadB:  48, max:   10, pos:(   0,    0)
RadS:  36, max:   11, pos:(  61,   29)
RadB:  42, max:   10, pos:(  62,   23)
RadS:  12, max:   11, pos:(  61,   99)
RadB:  39, max:    8, pos:(  51,  107)
RadS:  12, max:   10, pos:(  61,   95)
RadB:  44, max:   10, pos:(  43,  113)
RadS:  10, max:   11, pos:(  95,   16)
RadB:  39, max:    9, pos:(  42,   99)
RadS:  10, max:   10, pos:(  91,    8)
RadB:  54, max:    8, pos:(  60,    9)
RadS:  13, max:   20, pos:(  94,    0)
RadB:  40, max:    8, pos:(  38,  124)
RadS:  11, max:    9, pos:(  61,   83)
RadB:  45, max:    8, pos:(  35,   89)
RadS:  12, max:   13, pos:(  60,   82)
RadB:  39, max:    8, pos:(  41,   86)
RadS:  29, max:   13, pos:(  51,   84)
RadB:  40, max:    9, pos:(  41,   85)
RadS:  13, max:   13, pos:(  59,   82)
RadB:  48, max:   11, pos:(  32,   85)
RadS:  12, max:   10, pos:(  59,   84)
RadB:  43, max:    9, pos:(  37,   85)
RadS:  18, max:   11, pos:(  52,   83)
RadB:  43, max:   12, pos:(  35,   87)
RadS:  10, max:   12, pos:(  53,   78)
RadB:  53, max:   11, pos:(  24,   88)
RadS:  29, max:   11, pos:(  49,   93)
RadB:  39, max:    9, pos:(  36,   88)
RadS:  19, max:   13, pos:(  44,   85)
RadB:  43, max:    8, pos:(  27,   88)
RadS:  24, max:   12, pos:(  34,   85)
RadB:  40, max:    8, pos:(  22,   88)
RadS:  23, max:   10, pos:(  31,   87)
RadB:  39, max:    7, pos:(  11,   88)
RadS:  21, max:    9, pos:(  45,   94)
RadB:  48, max:    8, pos:(   0,   95)
RadS:  24, max:    9, pos:(  24,   91)
RadB:  39, max:    7, pos:(   0,   95)
RadS:  12, max:   11, pos:(  43,   90)
RadB:  42, max:    8, pos:(  24,   90)
RadS:  24, max:   11, pos:(  29,   84)
RadB:  49, max:   10, pos:(  13,   72)
RadS:  31, max:   12, pos:(  36,   78)
RadB:  44, max:   13, pos:(  23,   87)
RadS:  34, max:    8, pos:(  13,   55)
RadB:  56, max:   11, pos:(  10,   73)
RadS:  21, max:    8, pos:(  42,  146)
RadB:  53, max:    7, pos:(  12,   57)
RadS:  10, max:    6, pos:(   3,  104)
RadB:  39, max:    6, pos:(  40,   30)
RadS:  12, max:    8, pos:(  16,  108)
RadB:  41, max:    5, pos:(  42,  104)
RadS:  20, max:   12, pos:(  16,  106)
RadB:  44, max:    5, pos:(   0,   88)
RadS:  26, max:    7, pos:(  77,   71)
RadB:  45, max:    6, pos:(  58,  106)
RadS:  22, max:    9, pos:(  73,  129)
RadB:  39, max:    8, pos:(  48,  105)
RadS:  15, max:    8, pos:(  96,   79)
RadB:  40, max:    8, pos:(  82,  105)
RadS:  13, max:    7, pos:(  35,  129)
RadB:  40, max:    5, pos:(  81,  103)
RadS:  11, max:   14, pos:(  26,  109)
RadB:  39, max:    7, pos:(   0,  113)
RadS:  10, max:   14, pos:(  28,  110)
RadB:  39, max:   10, pos:(   0,  113)
RadS:  10, max:   19, pos:(  30,  110)
RadB:  47, max:    8, pos:(   0,  106)
RadS:  18, max:    9, pos:(  15,  135)
RadB:  42, max:    9, pos:(  65,  113)
RadS:  13, max:   10, pos:(  26,   78)
RadB:  65, max:    9, pos:(  75,   90)
RadS:  11, max:   20, pos:(  47,   96)
RadB:  42, max:    9, pos:(  68,  112)
RadS:  36, max:   14, pos:(   0,   29)
RadB:  44, max:    8, pos:(  71,   76)
RadS:  17, max:   14, pos:(  51,   83)
RadB:  40, max:    7, pos:(  38,   78)
RadS:  18, max:   20, pos:(  51,   80)
RadB:  42, max:    9, pos:(  38,   74)
RadS:  18, max:   23, pos:(  53,   82)
RadB:  47, max:    8, pos:( 109,   29)
RadS:  19, max:   21, pos:(  53,   85)
RadB:  42, max:    8, pos:(  41,   80)
RadS:  18, max:   17, pos:(  54,   87)
RadB:  41, max:    7, pos:(  35,   87)
RadS:  18, max:   22, pos:(  53,   89)
RadB:  44, max:   11, pos:(  32,   87)
RadS:  17, max:   14, pos:(  56,   89)
RadB:  41, max:    9, pos:(  38,   87)
RadS:  18, max:   15, pos:(  58,   87)
RadB:  56, max:    8, pos:(  87,  105)
RadS:  13, max:   12, pos:(  60,   87)
RadB:  42, max:   10, pos:(  40,   84)
RadS:  18, max:   16, pos:(  61,   87)
RadB:  39, max:    8, pos:(  44,   85)
RadS:  18, max:   18, pos:(  62,   88)
RadB:  41, max:   13, pos:(  44,   85)
RadS:  19, max:   16, pos:(  62,   88)
RadB:  43, max:   10, pos:(  42,   85)
RadS:  19, max:   16, pos:(  60,   87)
RadB:  44, max:   11, pos:(  39,   83)
RadS:  17, max:   15, pos:(  61,   86)
RadB:  42, max:   10, pos:(  72,   70)
RadS:  26, max:   14, pos:(  57,   88)
RadB:  39, max:   13, pos:(  70,   69)
RadS:  19, max:   17, pos:(  60,   88)
RadB:  42, max:   10, pos:(  41,   85)
RadS:  18, max:   16, pos:(  60,   87)
RadB:  41, max:   11, pos:(  42,   83)
RadS:  18, max:   14, pos:(  60,   87)
RadB:  39, max:    9, pos:(  44,   83)
RadS:  23, max:   16, pos:(  55,   88)
RadB:  45, max:   11, pos:(  37,   85)
RadS:  19, max:   18, pos:(  59,   88)
RadB:  40, max:    9, pos:(  71,   69)
RadS:  19, max:   16, pos:(  59,   88)
RadB:  40, max:    9, pos:(  72,   69)
RadS:  20, max:   12, pos:(  59,   88)
RadB:  40, max:    8, pos:(  43,   82)
RadS:  20, max:   11, pos:(  60,   88)
RadB:  42, max:   10, pos:(  75,   69)
RadS:  18, max:   14, pos:(  62,   88)
RadB:  41, max:    9, pos:(  75,   71)
RadS:  12, max:   13, pos:(  62,   88)
RadB:  39, max:    9, pos:(  72,   72)
RadS:  20, max:   12, pos:(  59,   89)
RadB:  43, max:    8, pos:(  73,   78)
RadS:  12, max:   11, pos:(  61,   87)
RadB:  44, max:    9, pos:(  39,   82)
RadS:  21, max:   11, pos:(  61,   90)
RadB:  52, max:    8, pos:(  83,   71)
RadS:  18, max:   11, pos:(  61,   88)
RadB:  40, max:    8, pos:(  73,   73)
RadS:  12, max:   11, pos:(  60,   89)
RadB:  41, max:   11, pos:(  41,   84)
RadS:  19, max:   16, pos:(  65,   86)
RadB:  44, max:    7, pos:(  48,  113)
RadS:  18, max:   14, pos:(  59,   89)
RadB:  40, max:    7, pos:(  79,   89)
RadS:  19, max:   12, pos:(  58,   89)
RadB:  40, max:    8, pos:(  41,   84)
RadS:  30, max:   10, pos:(  44,   94)
RadB:  43, max:    9, pos:(  54,   86)
RadB:  41, max:    7, pos:(  34,   89)
RadS:  11, max:    8, pos:(  62,   88)
RadB:  58, max:    7, pos:(  16,   86)
RadS:  11, max:    9, pos:(  60,   87)
RadB:  46, max:    8, pos:(  50,   86)
RadS:  10, max:    8, pos:(  74,   51)
RadB:  48, max:    9, pos:(  46,   84)
RadS:  10, max:   10, pos:(  74,   50)
RadB:  40, max:    7, pos:(  54,   84)
RadS:  22, max:    9, pos:(  48,   86)
RadB:  40, max:    8, pos:(  51,   82)
RadS:  10, max:   10, pos:(  71,   51)
Segmentation done!
Segmentation done!
Drawing done!
Encoding done!
RadB:  43, max:    8, pos:(  67,   76)
RadS:  23, max:   11, pos:(  47,   95)
RadB:  41, max:    9, pos:(  64,   76)
RadS:  15, max:   10, pos:(  52,   92)
RadB:  44, max:    8, pos:( 113,   98)
RadS:  15, max:   11, pos:(  52,   94)
RadB:  54, max:    9, pos:(  75,   77)
RadS:  17, max:   10, pos:(  50,   86)
RadB:  49, max:    7, pos:(  76,   96)
RadS:  17, max:   10, pos:(  49,   85)
RadB:  50, max:    7, pos:(  69,   74)
RadS:  11, max:   13, pos:(  53,   85)
RadB:  66, max:    9, pos:(  87,   75)
RadS:  12, max:    9, pos:(  55,   85)
RadB:  51, max:    7, pos:(  78,   87)
RadS:  12, max:   12, pos:(  56,   85)
RadB:  39, max:    7, pos:(  39,   82)
RadS:  12, max:   11, pos:(  56,   85)
RadB:  48, max:    7, pos:(  26,   81)
RadS:  12, max:   11, pos:(  57,   84)
RadB:  47, max:    9, pos:(  73,   86)
RadS:  11, max:   14, pos:(  59,   84)
RadB:  50, max:    8, pos:(  34,   73)
RadS:  12, max:   10, pos:(  61,   84)
RadB:  66, max:    9, pos:(  96,   82)
RadS:  11, max:   11, pos:(  64,   82)
RadB:  47, max:    8, pos:(  51,   90)
RadS:  11, max:   11, pos:(  64,   81)
RadB:  39, max:    7, pos:(  48,   80)
RadS:  26, max:    9, pos:(  66,   81)
RadB:  41, max:    9, pos:(  76,   63)
RadS:  26, max:    9, pos:(  68,   80)
RadB:  41, max:    8, pos:(  84,   80)
RadS:  27, max:   10, pos:(  70,   82)
RadB:  40, max:    9, pos:(  79,   62)
RadS:  12, max:    9, pos:(  66,   57)
RadB:  41, max:   10, pos:(   0,   97)
RadS:  26, max:    9, pos:(  68,   84)
RadB:  45, max:   10, pos:(  86,   82)
RadS:  20, max:   10, pos:(  58,   89)
RadB:  62, max:    8, pos:(  31,   93)
RadS:  23, max:   11, pos:(  51,   76)
RadB:  39, max:    7, pos:(  69,   86)
RadS:  11, max:    9, pos:(  59,   85)
RadB:  40, max:    7, pos:(  36,   85)
RadS:  29, max:   11, pos:(  56,   68)
RadB:  40, max:    8, pos:(   3,  130)
RadS:  11, max:    9, pos:(  57,   88)
RadB:  40, max:    7, pos:(  39,   83)
RadS:  10, max:   11, pos:(  57,   90)
RadB:  42, max:    7, pos:(  69,   76)
RadS:  31, max:   11, pos:(  58,   94)
RadB:  44, max:    8, pos:(  71,   90)
RadS:  10, max:   11, pos:(  58,   89)
RadB:  51, max:    7, pos:(  79,   89)
RadS:  11, max:   12, pos:(  58,   89)
RadB:  45, max:    7, pos:(  38,   83)
RadS:  11, max:   11, pos:(  58,   89)
RadB:  45, max:    9, pos:(  47,  102)
RadS:  20, max:   11, pos:(  56,   92)
RadB:  58, max:    9, pos:(  88,   88)
RadS:  10, max:    9, pos:(  59,   90)
RadB:  45, max:    8, pos:(  48,  103)
RadS:  20, max:    9, pos:(  56,   93)
RadB:  44, max:    7, pos:(  47,   99)
RadS:  20, max:   10, pos:(  57,   94)
RadB:  41, max:    7, pos:(  46,  112)
RadS:  10, max:    8, pos:(  59,   85)
RadB:  40, max:    8, pos:(  72,   81)
RadS:  10, max:   10, pos:(  60,   91)
RadB:  44, max:    7, pos:(  48,  100)
RadS:  22, max:    9, pos:(  55,   96)
RadB:  44, max:    7, pos:(  52,  111)
RadS:  10, max:    9, pos:(   0,   88)
RadB:  60, max:    8, pos:(  92,   90)
RadS:  10, max:   12, pos:(  61,   91)
RadB:  63, max:    8, pos:(  96,   83)
RadS:  10, max:   10, pos:(  61,   91)
RadB:  42, max:    7, pos:(  49,  100)
RadS:  20, max:   11, pos:(  57,   93)
RadB:  40, max:    7, pos:(  74,   94)
RadS:  10, max:    9, pos:(  59,   83)
RadB:  42, max:    7, pos:(  49,   99)
RadB:  42, max:    8, pos:(  78,   98)
RadS:  12, max:   11, pos:(   0,   87)
RadB:  64, max:    8, pos:(  96,   89)
RadS:  10, max:   11, pos:(  61,   91)
RadB:  39, max:    7, pos:(  43,   97)
RadB:  39, max:    7, pos:(  45,  108)
RadS:  10, max:    9, pos:(  61,   91)
RadB:  44, max:    7, pos:(  49,  103)
RadS:  10, max:   11, pos:(  61,   90)
RadB:  46, max:    9, pos:(  46,  100)
RadB:  46, max:    7, pos:(  79,   78)
RadB:  39, max:    7, pos:(  43,   90)
RadS:  10, max:   11, pos:(   0,   87)
RadB:  55, max:    8, pos:(  62,  101)
RadS:  10, max:   13, pos:(  60,   91)
RadB:  44, max:    8, pos:(  49,  102)
RadS:  10, max:    9, pos:(   0,   89)
RadB:  40, max:    7, pos:(  42,   85)
RadS:  36, max:    9, pos:(  38,  105)
RadB:  40, max:    6, pos:(  34,  103)
RadS:  33, max:   15, pos:(  26,  113)
RadB:  42, max:   11, pos:(   7,  104)
RadS:  21, max:   14, pos:(  86,   67)
RadB:  40, max:   12, pos:(  41,  123)
RadS:  13, max:   13, pos:(  71,   92)
RadB:  41, max:    9, pos:(   0,   32)
RadS:  27, max:   15, pos:(  85,   90)
RadB:  59, max:   10, pos:(  30,   93)
RadS:  11, max:   11, pos:(  35,  110)
RadB:  45, max:   11, pos:(  23,  102)
RadS:  14, max:   10, pos:(  58,  109)
RadB:  41, max:    7, pos:(  30,   81)
RadS:  10, max:   13, pos:(   0,   90)
RadB:  43, max:   10, pos:(   0,  154)
RadS:  11, max:   12, pos:(   6,   66)
RadB:  40, max:    7, pos:(  34,   99)
RadS:  13, max:    9, pos:(  61,   86)
RadB:  46, max:    7, pos:(  20,   78)
RadS:  31, max:   10, pos:(  44,   97)
RadB:  40, max:    6, pos:(  24,  154)
RadS:  17, max:   10, pos:(  22,   50)
RadB:  41, max:    9, pos:(  25,  157)
RadS:  22, max:    8, pos:(  49,   97)
RadB:  41, max:   10, pos:( 104,    0)
RadS:  21, max:   10, pos:(  49,   99)
RadB:  67, max:    9, pos:(   0,    0)
RadS:  15, max:   11, pos:(  85,    0)
RadB:  53, max:    9, pos:(  96,   78)
RadS:  12, max:   11, pos:(  82,    0)
RadB:  39, max:    7, pos:(  23,   95)
RadS:  12, max:    9, pos:(  82,    0)
RadB:  45, max:    8, pos:(  27,  107)
RadS:  14, max:   12, pos:(  56,   90)
RadB:  40, max:    9, pos:(  32,  101)
RadS:  29, max:   13, pos:(  39,   97)
RadB:  40, max:   10, pos:(  27,   96)
RadS:  28, max:   12, pos:(  39,   93)
RadB:  40, max:    9, pos:(  32,   96)
RadS:  30, max:   12, pos:(  42,   93)
RadB:  41, max:   11, pos:(  26,   92)
RadS:  13, max:   13, pos:(  83,    0)
RadB:  63, max:    8, pos:(  33,    0)
RadS:  31, max:   13, pos:(  42,   90)
RadB:  40, max:    9, pos:(  33,   91)
RadS:  31, max:   12, pos:(  43,   88)
RadB:  39, max:    7, pos:(  35,   89)
RadS:  33, max:   12, pos:(  42,   88)
RadB:  42, max:    8, pos:(  29,   73)
RadS:  27, max:   13, pos:(  44,   87)
RadB:  39, max:    7, pos:(  31,   75)
RadS:  14, max:   11, pos:(  83,    0)
RadB:  43, max:    9, pos:(  31,   71)
RadS:  18, max:   13, pos:(  60,   83)
RadB:  42, max:    8, pos:(  31,   85)
RadS:  29, max:   12, pos:(  45,   85)
RadB:  39, max:    8, pos:(  35,   74)
RadS:  16, max:   10, pos:(  64,   83)
RadB:  40, max:    6, pos:(  35,   73)
RadB:  47, max:    9, pos:(  36,   66)
RadS:  13, max:   10, pos:(  83,    0)
RadB:  42, max:    9, pos:(  36,   71)
RadS:  20, max:    9, pos:(  62,   85)
RadB:  39, max:    5, pos:(  36,   74)
RadS:  13, max:   12, pos:(  83,    0)
RadB:  41, max:    6, pos:( 118,  110)
RadB:  39, max:    6, pos:(  20,   78)
RadS:  27, max:   10, pos:(  55,   88)
RadB:  39, max:    9, pos:(  38,   75)
RadS:  12, max:   10, pos:(  82,    0)
RadB:  40, max:    8, pos:(  37,   75)
RadS:  21, max:    9, pos:(  61,   87)
RadB:  39, max:    7, pos:(  17,   79)
RadB:  39, max:    7, pos:(  19,   79)
Warming 10
Warming 9
Warming 8
Warming 7
Warming 6
RadS:  13, max:    9, pos:(  11,  114)
Warming 5
RadS:  30, max:   10, pos:(  19,   87)
RadB:  39, max:    7, pos:(  41,   76)
Warming 4
RadB:  39, max:    6, pos:(  40,   77)
Warming 3
RadS:  13, max:   11, pos:(  83,    0)
RadB:  40, max:    6, pos:(  13,  143)
https://linustechtips.com/topic/951203-zybo-and-raspberry-pi/#findComment-11568700
Segmentation done!
Segmentation done!
Drawing done!
Encoding done!
The logic of the program is kinda hard to follow, but it seems to require some time for it to really allow adding an user. Looks like it needs to try adding an user at least 4 times before it actually does so. So let it run for a while and check the textfile to see if it registered, just in case you've missed it succeeding.
Warming 10
Warming 9
Warming 8
Warming 7
Yeah, these aren't warnings, but just a way the author used to let the camera "warm" up (or more likely to adjust to the lighting conditions) before trying to match an iris. And because of the trivial way used to do it, it runs again and again each time a counter overflows.
It may very well be that the software is just broken.
https://linustechtips.com/topic/951203-zybo-and-raspberry-pi/#findComment-11568719
Yeah, these aren't warnings, but just thing the author used to let the camera "warm" up (or more likely to adjust to the lighting conditions) before trying to match. And because of the trivial method used to do it, it runs again and again as a counter overflows.
Thanks Nutler,
so basically i can run the program in my laptop instead of buying a zybo board?
https://linustechtips.com/topic/951203-zybo-and-raspberry-pi/#findComment-11568726
Just now, kivince said:
Thanks Nutler,
i will try running it later for a long period and see the results. and you mentioned that i can write away the rads and radb words and numbers that show up in the screen. Any idea how i can do that?
https://linustechtips.com/topic/951203-zybo-and-raspberry-pi/#findComment-11568729
Thanks Nutler,
No problem! And yes, it shouldn't at least work any better on zybo (or raspberry pi, which it should work on as well). It's a different question if it really works or not, or how much memory it may leak.
You can get rid of them by editing this part of the hough.c file: https://github.com/e-radu/irisRec/blob/608e718464e3b7358cd72be5ba2dac1abc0ea542/hough.c#L92,L107
You can basically just remove all those lines, run make again to recompile the source and then run the program to see the results.
https://linustechtips.com/topic/951203-zybo-and-raspberry-pi/#findComment-11568734
