Hey everyone.
I just purchased a PNY GTX 1070Ti  (dual fan) secondhand from ebay.
The seller did not use it in mining and they did not have any other cards for sale.
I love this card but it runs really hot. It will hit thermal limit (83C) after some time in Destiny 2
Doing some research I found that this particular card is just a hot one.
It seems to be more of a design flaw than usage thing.
That being said I don't think there is anything physically wrong with it.
Id like to find some creative ways to increase cooling performance.
Right now I have set a blower style fan on the end of the card and that actually did help by a couple degrees.
I've looked into aftermarket coolers but I believe I need a reference design for that to work.
What do you think? Whats a creative way to cool off a graphics card?
p.s. The case is a Corsair Carbide Air 540, so airflow is not a problem here.
https://linustechtips.com/topic/950988-hot-graphics-card/
1. Custom fan curve on GPU. (afterburner or similar)
2. Custom fan curve on intake and exhaust fans. (bios)
Main rig: i7 8086K // EVGA Z370 Micro // 16GB Gskill TridentZ 3200Mhz CL14 // Sapphire Pulse RX 7800XT// a variety of noctua cooling // Corsair RM750x v2 //  Fractal Meshify C
Secondary rig: R5 3600 // MSI B450i Gaming Plus // 16GB Gskill FlareX 3200CL14 // MSI GTX 1080ti Gaming X // Cooler Master V650 // Fractal Meshify C
Audio setup: Audient iD4 // Adam A7X // Sennheiser HD 650 // Sennheiser HD 25-II // Audio Technica M50x // Sennheiser Momentum 4
https://linustechtips.com/topic/950988-hot-graphics-card/#findComment-11563479
1 hour ago, airdeano said:
unless the software can increase the fans enough to lower the temps without deafening noise, i'd look to a watercooling solution:
nzxt g12 and corsair h50 AIO:
https://www.nzxt.com/product-overview/kraken-g12
Yea I've considered that. I'm just terrified of water cooling.
My thought process is if there were to be a leak, I wouldn't be able to afford to replace the hardware thast was damaged.
Plus I would still want to have the RAM chips and VRMs to be cooled
Did that already...
That didn't seem to help too much
https://linustechtips.com/topic/950988-hot-graphics-card/#findComment-11563619
5 minutes ago, fastcar123 said:
Did that already...
Does running all fans at 100% help at all?
https://linustechtips.com/topic/950988-hot-graphics-card/#findComment-11563638
1 hour ago, fastcar123 said:
Hey everyone.
Have you opened it up to clean out any gunk and replace the thermal paste? I'd be surprised if that was the issue on a card that new, but you never know.
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
https://linustechtips.com/topic/950988-hot-graphics-card/#findComment-11563650
It does slow the eventual heating to 75. But it's also loud as hell.
I didn't try that. I was going to attempt to perserve the void sticker if possible but I haven't tried it
https://linustechtips.com/topic/950988-hot-graphics-card/#findComment-11564236
Excellent point. If it's in warranty, don't open it. Just blow it out with compressed air.
https://linustechtips.com/topic/950988-hot-graphics-card/#findComment-11564241
The seller said that they never registered it so it very likely still has a warranty. It's definitely worth looking into. I'll have to check tomorrow.
If the warranty is not valid I'd like to see if an aftermarket air cooler would fit.
Even if the PCB isn't reference (I actually don't know if it is or isn't)
I've also contemplated using a CPU cooler and modfiying it to fit. That's a bit of a stretch though.
https://linustechtips.com/topic/950988-hot-graphics-card/#findComment-11564262
