9 minutes ago, Brasdos said:
Hi I’m going to build a pc and I’m wondering roughly how much radiators restrict airflow in CFM. I will be using static pressure fans on a 30 mm thick radiator with 3 exhast fans. Thanks.
To a certain degree but nothing that will affect the performance to a big degree with good pressure optimized fans. What will determine the amount of restriction is the thickness and FPI (fin density).
Does it matter how much it effects it? Is there some deciding factor here?
