Hi Everyone,
This is my first time building a computer and these are the parts I have selected (The case is not final and I have the opportunity to change it).
CPU: i5 8600K
Cooler: Cryorig H7
Motherboard: Asus ROG Strix Z370-F
RAM: 2x8gb G-Skill TridentZ RGB
PSU: Corsair RM750x 750w PSU
GPU: Asus ROG Strix 1080 (1836MHz)
Case: Corsair 275R
Please let me know your opinions of my selection and give me any tips you have to complete my build with as few hitches as possible.
Note: I probably won’t be overclocking immediately but I plan to do so after a few years after upgrading my cooling solution.
https://linustechtips.com/topic/950768-tips-and-recommendations-for-first-build/
The PSU is overkill. You don't need 750W. 550W will be plenty already.
CPU: Ryzen 7 9800X3D Cooler: Noctua NH-D15 Black Mobo: Gigabyte X870E Aorus Pro GPU: Sapphire Nitro+ 9070 XT RAM: G.Skill 2x16GB @ 6400 MHz SSD: PNY XLR8 2TB PSU: Corsair RM1000x Case: Fractal Design North Monitor 1: Asus XG27AQWMG(280Hz) Monitor 2: Asus VG259QM (240Hz)
I usually edit my posts immediately after posting them, as I don't check for typos before pressing the shiny SUBMIT button.
Unraid Server
CPU: Ryzen 5 7600 Cooler: Noctua NH-U12S Mobo: Asus B650E-i RAM: Kingston Server Premier ECC 2x32GB (DDR5) SSD: Samsung 980 2x1TB HDD: Toshiba MG09 1x18TB; Toshiba MG08 2x16TB HDD Controller: LSI 9207-8i PSUCorsair SF750 Case: Node 304
I’ve already ordered it so I guess I’ll just keep it now. And surely I’d need more than 550w if I were to overclock in the future wouldn’t I?
14 minutes ago, SMGVirus said:
Build looks good just get the Noctua NH-D15
I had this cooler on my FX8350 and i was able to be stable at 5.1GHz its a great air cooler if not the best and its around $70 give or take.
I thought about it but I thought it wouldn’t fit in the case. Especially because I’m using high profile ram. I don’t plan to do much other than gaming for a few years so I think I’ll stick to the cryorig. Thanks for your opinion though.
If In the US and comfortable switching the fan on your cooler possible to switch to the 110.3 CFM Scythe Slipstream on heatsinks with a 120MM fan to generally get between 40-60% more airflow. US cost is ~$10 bucks. Little loud at 37 Dba though.
Rawr.
No, not really. But it's okay, if you ever decide to go SLI (don't do it) you will have a PSU capable of holding two GPUs.
Unraid Server
I’m in Bahrain. It’s not that easy for me to change stuff because shipping on some items costs as much if not more than the price of the items.
Yeah. And I could even re-use it in other systems as power supplies don’t change much over the years.
6 hours ago, brbalusu said:
Also how much does it change in terms of price from 550w to 750w? I got mine for USD104-ish
$20 less for a good unit I guess.
Unraid Server
