Need input on a future build
Go to solution Solved by ne0tic,
27 minutes ago, BraydenSlayer said:
This will hopefully be my 2nd PC build, I would like to know if this is overkill or really good for "future-proofing" or being able to be upgraded in the next few years. BTW, this will be mainly used for gaming, and the occasional video editing and rendering.
CPU: Intel Core i7 8700k
Mobo: MSI Z370-A Pro
RAM: Corsair Vengeance 16GB (Thinking about 32GB, but I thought it was overkill)
Storage: 960GB SSD, 4TB 7200RPM HDD
GPU: MSI GeForce GTX 1080 8GB Gaming X 8GB
It's a good build for future proofing and if you have the money you should probably do it. But keep in mind that the GTX 11 series is about to come out so you may want to wait for that and maybe get a GTX 1170/1180 instead because they will probably be alot better than a GTX 1080!
Have a great day!
https://linustechtips.com/topic/949669-need-input-on-a-future-build/
Have a great day!
Corsair iCUE 4000X RGB
ASUS ROG STRIX B550-E GAMING
Ryzen 5900X
Corsair Hydro H150i Pro 360mm AIO
Ballistix 32GB (4x8GB) 3600MHz CL16 RGB
Samsung 980 PRO 1TB
Samsung 970 EVO 1TB
Gigabyte RTX 3060 Ti GAMING OC
Corsair RM850X
Predator XB273UGS QHD IPS 165 Hz
iPhone 13 Pro 128GB Graphite
6 minutes ago, seon123 said:
You might need a PSU and CPU cooler, and probably a case. Other than that, it's hard to tell, as you're missing some relevant information about the listed RAM and SSD, as well as which country you'll buy from.
Here is the complete part list excluding the fans which I have already picked out. I made a mistake on the case by cheaping out on it.
https://pcpartpicker.com/list/wJTtQZ
Have a great day!
Thanks for the advice, as I will build this PC overtime, I will wait for the GTX 11 Series.
Great choice!
Ryzen 5900X
Samsung 980 PRO 1TB
Samsung 970 EVO 1TB
Corsair RM850X
