try another DVI-DL cable, 144hz 1080p is pushing it for DVI-DL, it should be able to do it though since that has a proper DVI DL port and it's pushing more than 60hz (single link is rated to 1920x1200 @ 60hz maximum)
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
https://linustechtips.com/topic/949580-144hz-problem/#findComment-11551655
https://linustechtips.com/topic/949580-144hz-problem/#findComment-11551665
6 minutes ago, Zerkan said:
Can I get 144hz with an gtx 660ti? Im using an dvi dual link but i dont get any 144hz option in nvidia control panel or display settings, mby its the cable or the gpu?
That's an old part, so it's certainly not impossible that it can't. What sort of framterates can you confirm that you can run?
Also I've heard a lot of DVI cables have dual link connectros but the cable itself is missing the wires for that.
Main rig: i7 8086K // EVGA Z370 Micro // 16GB Gskill TridentZ 3200Mhz CL14 // Sapphire Pulse RX 7800XT// a variety of noctua cooling // Corsair RM750x v2 //  Fractal Meshify C
Secondary rig: R5 3600 // MSI B450i Gaming Plus // 16GB Gskill FlareX 3200CL14 // MSI GTX 1080ti Gaming X // Cooler Master V650 // Fractal Meshify C
Audio setup: Audient iD4 // Adam A7X // Sennheiser HD 650 // Sennheiser HD 25-II // Audio Technica M50x // Sennheiser Momentum 4
https://linustechtips.com/topic/949580-144hz-problem/#findComment-11551673
DL-DVI should give you 1080p 144hz max. But there is one issue that could be the problem. Active DVI is different than passive. DVI-I (passive) has 4 pins on the left for analog. You could be trying to connect a active port to a passive, causing issues.
Your HDMI on your GPU will do 1080p 144hz easily. So I recommend that.
Please quote me or @ me in your response so I get a notification.        I really really really really like small text.
Occupation: Gamer | Hours: 24/7 Full-Time | Hourly Pay: 0 | Benefits: Chick Magnet
FINISHED BUILD - VIEW PROFILE
If you say I'm not always right, but I am, I will say I am right.
rekt
https://linustechtips.com/topic/949580-144hz-problem/#findComment-11551703
I couldn't get 144hz on mine, but found it. It's on the page in the picture, and you scroll through the options of resolution and each one has categories. Select pc 1080p and then your can change the hz to 144 after you've applied the settings. In the pictrue it shows HD, SD, and you'll need to find the PC category
LL
LTT's Fastest single core CineBench 11.5/15 score on air with i7-4790K on air
Main Rig
CPU: i7-4770K @ 4.3GHz 1.18v, Cooler: Noctua NH-U14S, Motherboard: Asus Sabertooth Mark 2, RAM: 16 GB G.Skill Sniper Series @ 1866MHz, GPU: EVGA 980Ti Classified @ 1507/1977MHz , Storage: 500GB 850 EVO, WD Cavier Black/Blue 1TB+1TB,  Power Supply: Corsair HX 750W, Case: Fractal Design r4 Black Pearl w/ Window, OS: Windows 10 Home 64bit
Plex Server WIP
CPU: i5-3570K, Cooler: Stock, Motherboard: ASrock, Ram: 16GB, GPU: Intel igpu, Storage: 120GB Kingston SSD, 6TB WD Red, Powersupply: Corsair TX 750W, Case: Corsair Carbide Spec-01 OS: Windows 10
Lenovo Legion Laptop
CPU: i7-7700HQ, RAM: 8GB, GPU: 1050Ti 4GB, Storage: 500GB Crucial MX500, OS: Windows 10
https://linustechtips.com/topic/949580-144hz-problem/#findComment-11551744
Check for the proper cable and using the correct port on the card.
If not, just lower it to 120.
https://linustechtips.com/topic/949580-144hz-problem/#findComment-11555034
