Hello, I was just wondering where each component in a custom loop goes and which order they go in on the loop. From what I have read it starts at your reservoir then to pump. Then to cpu then graphics cards then to a radiator. Is this correct or do you put a radiator after the cpu.
https://linustechtips.com/topic/949362-first-liquid-cooling/
The order doesn't matter as long as the res is above and just before the pump to ensure it gets a constant feed and doesn't run dry.
https://linustechtips.com/topic/949362-first-liquid-cooling/#findComment-11549524
