100% gpu usage low fps
Go to solution Solved by Shmoofle,
Turns out its a defective card
So i bought a used 1060 3gb and before that i used a 1060 6gb but i let my brother use it in his rig because i only play on 1080p and dont need much vram. the problem is that after i replaced it the gpu goes to 100% usage but only getting around 10 fps even on the menu of rainbow six siege. before i would only get around 50-70% usage on the gpu and get a comfortable stable 60 fps in multiplayer on smaller maps. I know its not thermal throttling because i make sure to make temps a priority and it never goes above 65 C. Im using a shitty prebuilt so my cpu bottlenecks it anyway(i got an old a10 7800) but why would be much different now. This never happened before with my 6gb model. It might just be a coincidence because i just got a windows 10 update so im not sure if that is causing it. I would be very thankful for a solution because its something that i really look forward to come home and enjoy my game but i cant when its unplayable.
https://linustechtips.com/topic/949309-100-gpu-usage-low-fps/
Could try reinstalling the nvidia drivers, and doing a clean installation.
LTT's Fastest single core CineBench 11.5/15 score on air with i7-4790K on air
Main Rig
CPU: i7-4770K @ 4.3GHz 1.18v, Cooler: Noctua NH-U14S, Motherboard: Asus Sabertooth Mark 2, RAM: 16 GB G.Skill Sniper Series @ 1866MHz, GPU: EVGA 980Ti Classified @ 1507/1977MHz , Storage: 500GB 850 EVO, WD Cavier Black/Blue 1TB+1TB,  Power Supply: Corsair HX 750W, Case: Fractal Design r4 Black Pearl w/ Window, OS: Windows 10 Home 64bit
Plex Server WIP
CPU: i5-3570K, Cooler: Stock, Motherboard: ASrock, Ram: 16GB, GPU: Intel igpu, Storage: 120GB Kingston SSD, 6TB WD Red, Powersupply: Corsair TX 750W, Case: Corsair Carbide Spec-01 OS: Windows 10
Lenovo Legion Laptop
CPU: i7-7700HQ, RAM: 8GB, GPU: 1050Ti 4GB, Storage: 500GB Crucial MX500, OS: Windows 10
https://linustechtips.com/topic/949309-100-gpu-usage-low-fps/#findComment-11548981
Try swapping the 3gb into your brothers rig and see if it still has issues. If it does, you might need to RMA it. Your post is worded that you bought it, pulled your gpu, swapped the new 3gb in, and gave your brother the 6gb.
Main Rig
Plex Server WIP
https://linustechtips.com/topic/949309-100-gpu-usage-low-fps/#findComment-11549010
yeah but i bought it used so i cant really do anything about rma but ill test it on a different computer
https://linustechtips.com/topic/949309-100-gpu-usage-low-fps/#findComment-11549047
