Hey I currently have a macbook Air i5 with 4gb ram it's starting to show its age and I'd like to replace it with a new machine , I have an iPhone 8 and an old ipad so I am I'm the apple ecosystem .I personally considered a 2018 pro 13 with touchbar with the following specs
I5 8250 4c/8t
16 gb ram
256/512 gb ssd  (would 256gb be enough if I didn't store photos and just had a few apps)
Would this be a major update from my current machine ?Also macs aside what are your recommendations for an Air replacement?
https://linustechtips.com/topic/948793-macbook-air-replacement/
only 4gb of ram? I'm surprised you still use this as a main machine today. I'm using over 6GB of ram with two safari tabs and the usual stuff running in the background like dropbox etc.
She/Her
Phone: OnePlus Nord CE 5G | 128GB | 8GB Ram
Main Desktop: Ryzen 5 3600 | GTX 1060 6GB | 32GB Ram
Main Laptop: Acer Aspire V3-771G | Core i7 3612QM | 16GB
https://linustechtips.com/topic/948793-macbook-air-replacement/#findComment-11543713
I'd say that machine will be a massive upgrade, yes. I personally wouldn't go for a Windows laptop if you're already deep in Apple's ecosystem so I'm not going to recommend anything from that side.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
https://linustechtips.com/topic/948793-macbook-air-replacement/#findComment-11543714
6 minutes ago, Firewrath9 said:
Mabye upgrade the storage yourself with a samsung 850 evo, 200$ can get you 1tb of storage.
as far as I know the storage in the 2018 MacBook Pro is not user upgradable.
EDIT: and even if it was, Apple would void your warranty if you did it. so not worth it.
She/Her
https://linustechtips.com/topic/948793-macbook-air-replacement/#findComment-11543740
Impossible. MBP 2016 and onwards have soldered SSDs and the models before it have non-standard Apple custom m.2 SSDs.
https://linustechtips.com/topic/948793-macbook-air-replacement/#findComment-11543742
I can hear the wallets screaming from here.
Current: R2600X@4.0GHz\\ Corsair Air 280x \\ RTX 2070 \\ 16GB DDR3 2666 \\ 1KW EVGA Supernova\\ Asus B450 TUF
Old Systems: A6 5200 APU -- A10 7800K + HD6670 -- FX 9370 + 2X R9 290 -- G3258 + R9 280 -- 4690K + RX480
https://linustechtips.com/topic/948793-macbook-air-replacement/#findComment-11543754
1 minute ago, Hans2020 said:
Would the 256 drive be enough though ?
I'd say that vastly depends on your needs, so it's kind of hard telling you anything about that unless you tell us about them... :P
Make sure to tag and/or quote people so they get notified... :P:D
My gear:
                                                         Ryzen 7 2700X / Gigabyte GA-X370M-Gaming 3 / R9 380 Nitro 4GB/ 16GB DDR4 2133 / 225GB OCZ Trion 100 / 3TB of hard drive storage
        AOC C24G1 / BenQ GW2270H(rarely overclocked to 87Hz :P )
        Razer Blackwidow / Redragon Kumara / Logitech G Pro Wiress / Sennheiser HD 559
        Microsoft LifeCam Studio / Tonor BM700 microphone
Panasonic Lumix DC-FZ82 / Canon EOS 80D
#PCMasterrace
https://linustechtips.com/topic/948793-macbook-air-replacement/#findComment-11543801
really? how much was that core i7 laptop you have? including the RX480 and stuff? probably enough to fund a 13" MacBook Pro.
how much do you have now? I'm guessing 128?
She/Her
https://linustechtips.com/topic/948793-macbook-air-replacement/#findComment-11543804
I won't store massive files , just discord chrome apple apps and updates and maybe some documents.
apple apps? that's vague. I assume you meant pages etc. but just to be clear.
She/Her
https://linustechtips.com/topic/948793-macbook-air-replacement/#findComment-11543826
Sounds like 256 would be enough. I personally have a NAS so I store large files there. Having wireless 802.11ac across the house also helps ;)
https://linustechtips.com/topic/948793-macbook-air-replacement/#findComment-11543831
Just because you asked
~traded for the laptop(I'll say its worth 700 Used) ~200 for the Thunderbolt Dock(on sale) ~220 For the GPU 2 years ago Rough total $1120 VS the Base model macbook pro "starting at 1299.99" :P
https://linustechtips.com/topic/948793-macbook-air-replacement/#findComment-11543834
I mean macOS  updates are rather tiny right so there won't be an issue here?
https://linustechtips.com/topic/948793-macbook-air-replacement/#findComment-11543843
fair enough. I just don't like meaningless 'oh apple stuff is overpriced' comments.
She/Her
https://linustechtips.com/topic/948793-macbook-air-replacement/#findComment-11543851
Honestly I'd prefer to pay for mac that will last rather than a lenovo/Huawei/dell which will probably last a while but will have vastly inferior build quality and will lack macOS
https://linustechtips.com/topic/948793-macbook-air-replacement/#findComment-11543859
yeah HP= Horrible Product
I'm actually going to meet a guys to sell it tonight because I really don't like it
https://linustechtips.com/topic/948793-macbook-air-replacement/#findComment-11543875
Well, point releases are usually between a few hundred megs and 2 gigs, so small is relative here. Lol.
https://linustechtips.com/topic/948793-macbook-air-replacement/#findComment-11543876
My concern is that system updates my clog that little 256 drive
Nah, it's not like Windows where they stay on the disk until the OS or user finally decides to clean them up after a few weeks.
https://linustechtips.com/topic/948793-macbook-air-replacement/#findComment-11543975
