I am looking to get into water cooling and I have no idea where to start. I will move my build to the Arc Mini R2 from the Prodigy M. I will be able to use a 360mm rad up top because I don't need an ODD. I would prefer red tubing and red coolant to match my build. The parts that I think you need to know are:
4770k
780 ti EVGA superclocked
ASUS Maximus VI Gene
Thanks
CPU: i7-4770k CPU Cooler: NH-D14 RAM: Crucial Ballistix Sport 8gb GPU: EVGA Superclocked 780 ti MOBO: ASUS Maximus VI Gene PSU: Corsair RM 850 Case: Bitfenix Prodigy M
https://linustechtips.com/topic/94791-watercooling-noob-help/
You need
Pump
Res
Rad
Blocks
Tubing
Coolant
Fittings (buy a couple spare)
If going red coolant get clear tubing. Primochill advanced lrt
Res before pump.
Take a look at the 101 thread/faq in the stickies
I did, but could you recommend some good rads (would prefer the inlet and outlet to be on opposite side) and most of the other parts. I would want a res that is one of the clear cylinder reservoirs. Also, this is how it should go: Res-> pump-> components-> rad->res. Is that correct. Bear with me, it is my first time :P.
https://linustechtips.com/topic/94791-watercooling-noob-help/#findComment-1275020
The order of the components don't matter to much as the liquid move through quite quickly. The only thing that really matters is that your reservoir is above your pump.
There are heaps of brands that make radiators. I don't know if anyone would say that any are 'bad'. Alphacool, XSPC, EK, AquaComputer there are heaps out there. Just go to any online web store and look through their range and if you're unsure post it on here to get your decision verified. The only real thing that you may be concerned about with radiators is the FPI or Fins Per Inch. The lower the FPI the better suited for low speed fans, the Higher FPI requires higher RPM fans but does offer better cooling performance.
https://linustechtips.com/topic/94791-watercooling-noob-help/#findComment-1275895
Do you know any rads with the inlet and outlet on opposite sides?
https://linustechtips.com/topic/94791-watercooling-noob-help/#findComment-1277366
What about the XSPC Raystorm? It has everything needed to start, except the 780 block.
Oneplus 6 | Sony 55" X900F . Lenovo Y540 17" 144Hz RTX 2060 . i7 9750h.
Audio-GD DAC-19MK3 > Schiit Lyr 2 + > FOSTEX TH900 . Sony XBA-Z5
https://linustechtips.com/topic/94791-watercooling-noob-help/#findComment-1277555
Opposite sides or opposite ends?
All have opposite sides, the Alphacool have a lot of inlet outlet options, the AquaComputer have the most inlet/outlet options that im away of on any radiator.
https://linustechtips.com/topic/94791-watercooling-noob-help/#findComment-1280207
Opposite ends, my bad
https://linustechtips.com/topic/94791-watercooling-noob-help/#findComment-1280415
i think he is talking about the XSPC EX series crossflows
 CPU: i5-6600k MOBO: ASUS Z170 Pro Gaming RAM: G.Skill 16GB 2800Mhz 15-15-15-35, GPU: Sapphire R9 290 SSD: Samsung 840 250GB HDD: Seagate Barracuda 2TB x2, Cooling: EK supremecy EVO ,EK-FC R9 290X with backplate, XSPC EX240 Crossflow & Alphacool UT60 240mm, XSPC D5 Bayres w/ Alphacool VPP655, 7/16-5/8 Compressions/Tubing, Noctua NF-F12 x4 PSU: Silverstone Strider Plus 850W Case: Nanoxia Deep Silence 1 http://valid.x86.fr/8g2m02
https://linustechtips.com/topic/94791-watercooling-noob-help/#findComment-1280458
SO MUCH FANCY WATERCOOLING TALK :P
But is the one you are talking about have the inlet/outlet on one end and the other on the other end?
https://linustechtips.com/topic/94791-watercooling-noob-help/#findComment-1280545
Yeah I have one of the 240mm versions and it helps cut down tubing if you need to go to the other side of the case. The only bad thing is it is only 35mm thick and it has a high FPI (fins per inch) so you will need to run the fans a little higher RPM. It keeps my CPU pretty cool with a 1Ghz oc
https://linustechtips.com/topic/94791-watercooling-noob-help/#findComment-1281158
