Well, your case should come with fans, so you shouldn't need the extra ones, but don't quote me on that. The board looks like it has 1 CPU fan header and 3 SYS fan headers, so if you want 3 fans, no, but more than that, you need it.
Or did you mean the RGB splitter cable?
https://linustechtips.com/topic/947908-please-help/#findComment-11536274
yeah, my dad just ordered the parts.
https://linustechtips.com/topic/947908-please-help/#findComment-11536281
... Bruh no.
Get rid of the STUPID AIO and get an air cooler and a better GPU like the 1060 or if prices are good, the 1070.
Don't get that thermal paste because it's nog going to be any better than what comes with today's coolers, AS5 might even be worse.
Cut the fans, case already comes with three and get a lower wattage PSU to save more money again, it's not a bad unit though but I'd get something else either a 650W or 500W.
Builds:
https://linustechtips.com/topic/947908-please-help/#findComment-11536348
For thermal paste use this: https://de.pcpartpicker.com/product/XHqbt6/thermal-grizzly-kryonaut-1g-1g-thermal-paste-tg-k-001-rs
It is top tier thermal compound, close to the only things that beat it are liquid metal ones, and it comes in at an insanely reasonable price.
Rawr.
https://linustechtips.com/topic/947908-please-help/#findComment-11536351
