Need advise on Fan direction.
Solved by BlueChinchillaEatingDorito,
2 minutes ago, Edward666 said:Thanks man.
Yeah putting top right fan in push out direction would be idiotic coz i will dismiss air flow from front fans. i'm just thinking same top right one might be become a blockage for air coming from front ? and top left is pushing hot air down towards GPU pcb which is coming from the CPU heatsink or not ?
i just followed more cooler air in then more hot air out rule .
It shouldn't be a problem. In all honesty, without the use of shrouds, air just vaguely ends up where you think it goes.
