So recently I started playing CS:GO again on my new pc but when I installed it the fps count was very low not going above 80 and usually sticking around 60, I have tried uninstalling it and reinstalling it. I am running an intel i7 7700k kady lake with a ROG Nvidia Geforce 1080ti. On my other games such as overwatch or fortnite, I get around 150-200 fps running at highest settings for my 2k monitor with 165hz. Please help.
https://linustechtips.com/topic/947855-csgo-really-low-fps-please-help/
Make sure v-sync is off in-game and in the nvidia control panel for CS:GO.
You could also try adding some launch options such as
-freq 165 +fps_max 165 -high -threads 8 -nod3d9ex -novid
If you want to use the new UI, add the launch option
-panorama
If you want to up the max FPS at all, increase the +fps_max launch option.
