frankenstien build happened - a year later gpu temps are extreme
Solved by mzlink,
On 7/14/2018 at 9:46 PM, ZeusXI said:put you fingers around the tubes. if its vibrating, it should be working. turn off all other fans in case, and put your ear next to the gpu. the pump is inside, so listen to the hum of a pump
I'll do some tests tomorrow then and report back.
Update: local chap bought it. No longer a problem for me.
