Stand for Xm8500
Kabom
So,
Would this stand work together with the XM8500?
Or, if you got a better solution please list it below.
It should, the clip on the stand appears to be compatible with the body of the XM8500, but be warned that you get what you pay for. If it's ever in your budget I highly recommend getting the Rode PSA1.
PC Specs:
CPU: AMD 1700x Cooler: Corsair H100i V2 Motherboard: Asus Crosshair VI Hero RAM: 4 * 8GB G.Skill RGB DDR4 Graphics: EVGA GTX 1080 Ti SC2 Storage: Samsung 960 EVO 500GB Case: Fractal Design Meshify C PSU: EVGA 750w G3 Monitors: Dell SG2716DG +  2x Dell U2515H
Freenas specs:
CPU: Intel Xeon E5-2650 V2 Cooler: Some noctua cooler Motherboard: Supermicro X9 SRL-F RAM: 8 * 8GB Samsung DDR3 ECC Storage: 6 * 4TB Seagate 7200 RPM RAIDZ2 Controller: LSI H220 Case: Phanteks Enthoo Pro PSU: EVGA 650w G3
Phone: iPhone 6S 32 GB Space Grey
Maybe a bit over my budget.
Do you got any other recommendations?
The one you listed will be decent with your mic as it's a smaller and lighter microphone. My main complaint with a similar inexpensive arm was that it would sag under the weight of my blue yeti which is a very heavy mic. This said, the arm you posted should be fine as a starter arm especially considering it matches the cost of the XM8500.
PC Specs:
Freenas specs:
This one then. https://www.amazon.com/gp/product/B00AK7SKL4/ref=ox_sc_act_title_1?smid=ATVPDKIKX0DER&psc=1
2 minutes ago, Kabom said:
I don't think that one would be much better (if at all) than the original one you posted.
PC Specs:
Freenas specs:
37 minutes ago, Kabom said:
I have it and it holds my blue snowball just fine. i'd put something about the weight of a yeti on this and Id say it would probably hold. Good enough for his cheap mic.
I guess I'm a bit spoiled with the PSA1. :P The cheaper alternatives definitely do work though you do need to be more careful when adjusting them.
PC Specs:
Freenas specs:
Anyways, if it isn't good enough I can just return it and save up for some better stuff.
This was what I ultimately bought:
