Best monitor for League
HZapperz
I’m looking for possibly an ultra wide monitor to mainly play league on. I looked on amazon and there are like hundreds of different brands.
I was looking to spend around 500$, but I don’t really have a set budget.
I looked at some viotek monitors which seem to be pretty good deals, I just wanted your opinion on what you think I should get.
I don't have any specific recommendations, but just some information for consideration, I cannot tell the difference between 60 Hz and 165 Hz when playing League, so if you've been looking at any high refresh rate monitors I would say it's not very important if that's your main game.
