11 minutes ago, RZU said:
My 7700k not overclocked is idling at 67 degrees and if i game long enough it can get up to 86 any ideas?
What's your case and CPU cooler?
and I assume you haven't delidded it?
It doesn't matter until you're over 90C anyways though.
https://linustechtips.com/topic/945678-7700k-high-temps/#findComment-11515281
delid. kabylake is well known to be thermally crappy.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/945678-7700k-high-temps/#findComment-11515327
Better yet sell it and get Ryzen...probably not actually worth it though.
Find someone who will trade it for Ryzen 7
https://linustechtips.com/topic/945678-7700k-high-temps/#findComment-11515367
