Hi, my my gpu decided to let out The legendary cloud of blue smoke the other day, i decided to get a new case so i can get an actual full sized gpu. Any way, i found out that i Will also need a new psu, but im not sure witch one i should get. The build Will be this: i3 7100, Intel Stock cooler, evga 1050ti SSC, 2x4gb Kingston ddr4, Asus h110-a/m.2, 1tb 5400rpm harddrive from seagate. Keep in mind that im on a tight budget (im a teenager, so i havent got that much money.) I Washington thinking about this one https://www.corsair.com/us/en/Power/Plug-Type/vs-series-config/p/CP-9020049-NA, but im not sure. My budget for the psu is 60$.
https://linustechtips.com/topic/945549-help-with-psu/
The VS450 isn't really a great PSU. A Corsair CX450/CX450M is still in your budget and is far better.
https://linustechtips.com/topic/945549-help-with-psu/#findComment-11515243
Get the CX-M series, or if you don't want to try to get MIRs, go for the SeaSonic Focus Gold.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/945549-help-with-psu/#findComment-11515415
