AMD power limit
If you crash, it simply means too low Vcore, or might be too high memory clocks. Rising the power limit only helps you to avoid throttling under heavy load. In other words, if you see your clocks falling below what you set in after burner under heavy load, you need to raise your power limit. I always just set it to max and forget it. For high overclocking (once you have maxed default limits) you might need to edit GPU bios or registry powerplay tables, but this generally not for 24/7 use...
I might add that Furmark is not a good GPU stability tester for real word. It's only good for testing the cards power delivery. Use Unigine Heaven, Valley & 3Dmark Fire Strike or TimeSpy instead. Look for artifacts and glitches in these programs to determine stability, and then of course go and play your games.
