I'm trying to build a 1080p medium/low settings gaming set up that I can upgrade later. Budget is kinda tight, I've got a $800 max budget. This is also my first build.
Here's what I've scrounged up on pcpartpicker: LINK
I would like 16GB of ram, a 8th gen Intel CPU and SSD boot drive.
I'm also not sure if I should go with Corsair Vengeance LPX at DDR4-2400 or DDR4-3000, its only a $10 difference.
Any suggestions/changes? Is there anything else I need?
Real Life sucks, yes, the graphics are good but the characters are terrible, the story sucks and I can't find any quests.
https://linustechtips.com/topic/944999-first-build/
get your OS from reddit for $25 and use the money on something else. you don't need 16gb of ram, get 8gb now and use the money for a better GPU/CPU.
https://linustechtips.com/topic/944999-first-build/#findComment-11509538
PCPartPicker part list: https://pcpartpicker.com/list/Tc3Wr6
Price breakdown by merchant: https://pcpartpicker.com/list/Tc3Wr6/by_merchant/
CPU: AMD - Ryzen 3 1200 3.1GHz Quad-Core Processor  ($94.99 @ Newegg)
Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard  ($65.98 @ Newegg)
Memory: ADATA - XPG GAMMIX D10 16GB (2 x 8GB) DDR4-3000 Memory  ($149.90 @ Newegg)
Storage: Crucial - MX500 250GB 2.5" Solid State Drive  ($69.89 @ OutletPC)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($43.90 @ OutletPC)
Video Card: Gigabyte - Radeon RX 580 8GB Gaming 8G Video Card  ($269.99 @ Newegg)
Case: Cougar - MX330 ATX Mid Tower Case  ($24.99 @ SuperBiiz)
Power Supply: Corsair - CX (2017) 450W 80+ Bronze Certified ATX Power Supply  ($23.98 @ Newegg)
Total: $743.62
Generated by PCPartPicker 2018-07-06 12:10 EDT-0400
Get your OS from reddit.
I can do better if you are willing to give up  16GB of RAM
https://linustechtips.com/topic/944999-first-build/#findComment-11509544
Check out this build for $800 USD: https://pcpartpicker.com/list/CYy8Hh
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/944999-first-build/#findComment-11509545
assuming you're fine with rebates:
CPU: Intel - Core i5-8400 2.8GHz 6-Core Processor  ($178.99 @ Amazon)
Motherboard: MSI - H310M PRO-VD Micro ATX LGA1151 Motherboard  ($54.99 @ Amazon)
Memory: G.Skill - Aegis 16GB (2 x 8GB) DDR4-2400 Memory  ($139.99 @ Newegg)
Storage: Inland - 240GB 2.5" Solid State Drive  ($44.99 @ Amazon)
Storage: Toshiba - 1TB 3.5" 7200RPM Internal Hard Drive  ($42.99 @ Newegg Business)
Video Card: MSI - Radeon RX 580 8GB ARMOR MK2 OC Video Card  ($259.99 @ Newegg)
Case: DIYPC - DIY-F2-P MicroATX Mini Tower Case  ($29.98 @ Newegg)
Total: $775.90
Generated by PCPartPicker 2018-07-06 12:11 EDT-0400
https://linustechtips.com/topic/944999-first-build/#findComment-11509546
3 minutes ago, GoldenLag said:
Does that budget include monitor, peripherals and OS?
I have all the peripherals I just need the computer itself.
Is the reddit way of obtaining OS legit?
https://linustechtips.com/topic/944999-first-build/#findComment-11509552
they're fine, helps to save money when you don't have much for your rig.
https://linustechtips.com/topic/944999-first-build/#findComment-11509556
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($159.99 @ Amazon)
Motherboard: MSI - B350 PC MATE ATX AM4 Motherboard  ($59.99 @ Newegg)
Memory: Corsair - Vengeance LPX 8GB (1 x 8GB) DDR4-3000 Memory  ($87.99 @ Newegg)
Storage: Kingston - A400 240GB 2.5" Solid State Drive  ($53.83 @ Newegg Marketplace)
Storage: Western Digital - Caviar Black 1TB 3.5" 7200RPM Internal Hard Drive  ($64.99 @ Newegg Marketplace)
Video Card: EVGA - GeForce GTX 1060 6GB 6GB SC GAMING Video Card  ($279.99 @ Amazon)
Power Supply: SeaSonic - 520W 80+ Bronze Certified Fully-Modular ATX Power Supply  ($39.99 @ Newegg)
Total: $771.76
Generated by PCPartPicker 2018-07-06 12:51 EDT-0400
You can get the OS from reddit, and you could add more Ram later with another stick of ram.
https://linustechtips.com/topic/944999-first-build/#findComment-11509657
Motherboard: ASRock - AB350 Pro4 ATX AM4 Motherboard  ($73.98 @ Newegg)
Storage: Patriot - Burst 480GB 2.5" Solid State Drive  ($79.99 @ Amazon)
Video Card: EVGA - GeForce GTX 1060 3GB 3GB SC GAMING Video Card  ($225.00 @ Amazon)
Case: NZXT - S340 (White) ATX Mid Tower Case  ($59.99 @ SuperBiiz)
Total: $788.84
Generated by PCPartPicker 2018-07-06 12:59 EDT-0400
Tried best to keep you from getting ripped of but RAM is still inflatted 2-3x its normal price.
For your budget, you best stickign with a 3gb 1060, the 6gb and th e RX 580 are still inflatedi n price and wont give you anymore meaningful performance for the price.
This build also lacks a HDD but has a larger SSD , so no HDD noise, and fast loading times for all your software.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
https://linustechtips.com/topic/944999-first-build/#findComment-11509672
