EZ Debug LED
Go to solution Solved by Rainbow Dash,
Check if any of the pins on the cpu socket are bent, or any debris in the socket, then re-install the cpu. If that doesn't work, try running the RAM in a different slot.
Build:
16 Gigs of Ram PC17000 DDR4
i5-7500 3.4 ghz
MSI B250 Gaming Pro Carbon
GTX 1080TI ZOTAC ZT-P10810F-10P GeForce GTX 1080 Ti AMP Extreme Core Edition.
I just replaced the motherboard on my computer to the MSI B250 Gaming Pro Carbon.
Whenever I start the computer up the EZ Debug LED will blink on the cpu to the dram. Repeatedly.
https://linustechtips.com/topic/944883-ez-debug-led/
Thank you Rainbow Dash, when I removed the RAM from the slot and turned the computer on the EZ Debug didn't light up at all, so I moved it around a couple of times and finally got it to work. I'm now installing Windows on my NVME WD Black SSD. <3 Thank you again.
https://linustechtips.com/topic/944883-ez-debug-led/#findComment-11508347
