3 minutes ago, Mr.Br1an.1204 said:
So I'm building a pc for my mom and it will only be a web browsing/light flash game machine, I don't want to get her integrated, but is a 1030 better than integrated or should I get a 1050 or nothing?
thanks!
A while back I did a experiment with a 4790k. Played gta 5 on it with medium settings, 30 fps. Its not worth unless you wanna upsell your mom.
thanks!
As in you already have PC hardware and you need to throw in a GPU for video output?
Because you can use a much cheaper GPU and still be fine.
If you're building an entire new system just get an R3 2200G. Or just buy a laptop.
Yeah total waste of money to get a gpu for that. This is the rare instance I'd recommend a 2200g/2400g
Firestrike
i7-8700k @5.0GHz w/ 1.30v, Corsair h100iv2, Gigabye Aorus gaming 7, 16GB(8x2) 2666MHz ddr4, Dual RX470's OC'd to 1390mhz(atm) in corssfire - liguid cooled with corsair h60's, 3.25 TB in Samsung SSD's, anidees white crystal cube case
Retired:
i5-4440k @3.2GHz, gigabyte ga-z87x-ud5h z87, 24GB DDR3, 3x1TB Seagate Baracuda HDD.
Thanks, guys! I guess my ultimate (anything is better than integrated) PCMR friend, was wrong. Ima be going integrated and maybe spend that money on something that will actually improve performance, RGB. (don't hate it was a joke!!)
Also, I'm paying for it, so I don't wanna upsell myself.
yes, and i believe igpu in 8th are 630's, and can support 4k video, depending on the board, pretty much all i've seen though in the bios you can up the igpu vram to help it out some too btw.
Firestrike
Retired:
cool! I didn't know that. too bad my mom won't be able to utilize that. But that's really good to know!
well, you can always set it to 1gb, or so. I can't imagine those flash games need more then that lol
Firestrike
Retired:
ikr. but maybe 2 1080its in SLI just to be on the safe side... (poking at the kid who "needs a Quadro to run Minecraft, nevermind the fact that Java applications cant use CUDA acceleration)
tbh with you im surprised someone on here hasnt said you should get a 1050 or something. Isn't mindcraft like nintendo graphics anyways? i was surprised it needs any gpu lol last time i seen my daughter playing it im like this 1989 and a nintendo you have girl?
Firestrike
Retired:
I am too. but that is still so overpriced. (been eying that one for a light media center gaming pc.)
Im going to use 1 of my ra470's for a media center once new gen cards come out, even though this card is more then needed for that type of setup. If you weren't going to game on it also, you could pick something up cheap for a media center card. Im only upgrading mine cause i've finally ordered a 4k monitor and wanted to get into 4k gaming and my card, even in CF won't game 4k lol but does excellent at everything i've thrown at it at very high or ultra settings/
Firestrike
Retired:
As it was said above this is exactly the case for ryzen 2200g/2400g. 2200g is probably sufficient enough. Their igpus should perform roughly same as gt 1030. 2200gs vega 8 probably little bit worse and 2400gs vega 11 probably a bit better. Do not go for intel in this case, just not worth it.
Pair it with some b350/b450 board(if you get b350 make sure the bios is updated and compatible with raven ridge, b450 should be released like anytime probably).
Do not forget that these ryzen cpus benefit from fast ram so I would get atleast 3000 mhz sticks(2x4 would be probably enough).
And do not cheap out on psu. Look at psu tier list in Cases and psus section of the forum and pick one from t1 to t3. The good budget choice would probably be corsair cx450m
well, this is an entirely different pc. one that will actually be used for real gaming.
