Hello,
so 3 days ago i bought a new laptop (asus tuf fx504gd) with:
gtx 1050,
i5 8300h,
8gb of ram 2666mhz,
1tb sshd.
So after installing Windows 10 pro 64bit i went to try out some games. When i tried to launch csgo it didnt launch at all, in LoL i was getting around 10 fps on the lowest graphics same with other games. Finally i found an issue: in games gpu usage is 0%. Do you know how to fix this problem? I have installed the most recent drivers. However in cinebench when i was doing gpu test gpu was functioning normally.1530793817189479191895.jpg.5cf13ce6bf3671530797969680-1442441329.jpg
https://linustechtips.com/topic/944653-0-gpu-usage-in-games-help/
The graph tells you that the laptop uses the built in intel gpu, instead of nvidia gpu. You have to go to nvidia control panel, manage 3d settings, global settings, use nvidia gpu.
It seems like gpu1 is the intel gpu, while gpu 2 is your Nvidia gpu.
Have you installed the Nvidia drivers?
gpu1 is nvidia gpu and gpu2 is intel gpu. checked it in msi afterburner. I have installed latest nvidia drivers
disable the iGPU in bios.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
Easy to fix. Go to Nvidia Control Panel, manage 3D settings, set preferred GPU to Nvidia GPU. If you want to save some battery life, then only apply this to the programs you prefer to use dGPU (games for instance)
GPU 1 is 1050 while GPU 2 is iGPU
you can't disable iGPU in laptop BIOS unless it's GSync enabled
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
I already had done that but it doesnt help.
Then it may be a firmware/BIOS issue
Desktop specs:
well it can't be firmware issue, because laptop came wiithout OS. It might be bios issue, but when i tried to update bios, it froze, so i was forced to cancel bios update and restart computer. Now I'm afraid to brick my bios so I don't want to risk and try to update it once again.
You probably brick the BIOS
Desktop specs:
37 minutes ago, Instrange. said:
how to check if i did?
does it boot?
System specs:
1 hour ago, Instrange. said:
yeah it boots. Updated bios 10minutes ago everything is okay except for frame rates in games. cant fix this issue...
the BIOS isn't bricked, otherwise it wouldn't boot.
System specs:
