It might lower the life expectancy of your fans by a bit.
You shouldn't need your fans at 100% for that long though...
As long as your GPU isn't getting into the 90+ degree Celsius range, you'll be fine.
I run an overclocked GTX 780, fan only gets up to 60ish percent speed while gaming. Also for hours.
https://linustechtips.com/topic/944210-gpu-fan-speed/#findComment-11502139
I see... I should just set it to automatic then? Cuz when I game temp lis like 49-55ish
https://linustechtips.com/topic/944210-gpu-fan-speed/#findComment-11502185
No reason to worry about temperatures. Automatic should be fine, usually the default fan curve doesn't need much tinkering.
https://linustechtips.com/topic/944210-gpu-fan-speed/#findComment-11502189
