what different with both this cpu? A8-9600 and X4 950
and which is better for my build? i know you will ask why i choose this cpu because is budget my plan is about 5 or 8 month later i will upgrade this cpu to ryzen, and this is my first build
spec: gtx 1050Ti/4gb×2 ram/ asrock pro 4/ be quiet pure power 10 400W
https://linustechtips.com/topic/943884-recommend-am4-cpu-help-build-pc/
It would be far better to get a 1200 / 1300X CPU with that build than either the A8 or X4, both of which are refreshes of an old CPU architecture.
The 1200 can be found pretty cheaply now that the 2200g is out.
CPU - Core i7 4770 RAM - 16GB DDR3 1600MHz GPU - XFX RX 470 4GB
SSD - 1TB TCSUNBOW X3 PSU - 500W Aerocool Integrator
PCPartPicker part list: https://pcpartpicker.com/list/HHQDzY
Price breakdown by merchant: https://pcpartpicker.com/list/HHQDzY/by_merchant/
CPU: AMD - Ryzen 3 2200G 3.5GHz Quad-Core Processor  ($94.89 @ OutletPC)
Motherboard: ASRock - X370 Pro4 ATX AM4 Motherboard  ($59.99 @ Newegg)
Memory: Team - Vulcan 16GB (2 x 8GB) DDR4-3000 Memory  ($149.99 @ Newegg)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($43.90 @ OutletPC)
Case: Cougar - MX330 ATX Mid Tower Case  ($24.99 @ SuperBiiz)
Power Supply: Corsair - CX (2017) 650W 80+ Bronze Certified ATX Power Supply  ($44.99 @ Newegg)
Total: $418.75
Generated by PCPartPicker 2018-07-03 06:33 EDT-0400
Here is a full build. You will add a GPU later on. This will do 1080p gaming just fine
Total: $418.75
i see from random youtube video bench there are many shuttering and glitch graphic for game like BF1 it is true? or already fixed?,
That was an issue yes, but afaik there is a driver that solves the issue
Shows exactly the issue and how to solve it, maybe there are already drivers out that fixed it officialy
Total: $418.75
But he already has a Graphics card, a PSU  and probably storage as well.
3 hours ago, johan635 said:
if i build like this will it compatible? are there are any idea or fix for this issue?
https://pcpartpicker.com/list/mpMvZR
That build will work just fine. If you allready have a GPU you can grab an 1600 instead. It will provide more performance.
