camera power supply
Go to solution Solved by knightslugger,
You need a Fujifilm CP-04 Coupler and the AC-5VX power adapter.
So, i have a fujifilm S3280, it takes 4 AA batteries and i would like to connect it to the mains, it doesnt have a normal socket to input power, but it does have the little flap in the battery compartment for display power(for display in a store), where would i be able to get one of these store display adapters?
https://linustechtips.com/topic/943693-camera-power-supply/
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/943693-camera-power-supply/#findComment-11497579
