Hey, there's a slight problem with my monitor / pc connecting to Wifi.
I hooked up an ethernet cable to my pc and plugged the other end in the Lan slot on my router, and started up my pc, but unfortunately, the wifi icon was ordinary and had the "x" on it, for no internet.
I have a feeling maybe I incorrectly wired the motherboard or IO shield, but everything else on the motherboard and i/o shield seems to be working perfectly fine! I'm not keen on buying a WiFi PCI or any USB adapters.
SPECS: i7-8700 , GTX 1060 6GB , 2 TB HHD , 250 GB SSD , ThermalLake 750W RGB , Corsair Spec Omega ( White ) , HP Omen 25" 144hz Monitor
NOTE: I've tried restarting the router, monitor and pc but can't seem to find a fix..
CPU: Intel i7-8700
GPU: MSI GTX 1060 6GB GAMING X
Monitor: HP OMEN 25 144hz
RAM: 8GB G Skill
Motherboard: MSI B360 Gaming Arctic
Storage: 2TB Barracuda
Start-up: Samsung 250GB SSD
Case: Corsair Spec-Omega White
PSU: ThermalTake 750W Fully Modular RGB
Keyboard: Razer Blackwidow Tournament Edition X Chroma V2
Mouse: Razer Deathadder / Logitech G502
Speakers: Logitech Z200 White / Beats Earphones
https://linustechtips.com/topic/942978-ethernet-to-pc-problem/
Are the drivers installed from the motherboard website?
Was it working before? If it was, what changed?
What OS? Fresh install or existing?
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/942978-ethernet-to-pc-problem/#findComment-11491143
I just completed my pc build and haven't installed the drivers yet, Windows 10 is running from a usb stick.
No, it wasn't running before.
CPU: Intel i7-8700
RAM: 8GB G Skill
https://linustechtips.com/topic/942978-ethernet-to-pc-problem/#findComment-11491148
Ok, you'll need to install the drivers from the motherboard makers website.
Prior Build Log/PC:
https://linustechtips.com/topic/942978-ethernet-to-pc-problem/#findComment-11491151
How will I do it without internet, will I have to download them on a separate pc and transport the files using a usb stick?
CPU: Intel i7-8700
RAM: 8GB G Skill
https://linustechtips.com/topic/942978-ethernet-to-pc-problem/#findComment-11491158
Yah, pretty much. Phone if possible but they are usually a couple hundred MB in size so if you've got a low data limit I don't recommend that. If you've got a laptop or another computer just download from there and use USB as you said.
Prior Build Log/PC:
https://linustechtips.com/topic/942978-ethernet-to-pc-problem/#findComment-11491164
Alright, I'll attempt that, thanks.
CPU: Intel i7-8700
RAM: 8GB G Skill
https://linustechtips.com/topic/942978-ethernet-to-pc-problem/#findComment-11491170
 17:52 in this video it states only 4 drivers to install, should I only download these four, or all on this list - https://www.msi.com/Motherboard/support/B360-GAMING-ARCTIC#down-driver
CPU: Intel i7-8700
RAM: 8GB G Skill
https://linustechtips.com/topic/942978-ethernet-to-pc-problem/#findComment-11491176
I would do the first four on the list. Ignore the "Other Drivers" and "On-Board PIDE" ones
Prior Build Log/PC:
https://linustechtips.com/topic/942978-ethernet-to-pc-problem/#findComment-11491181
Thanks a lot, I will try now.
CPU: Intel i7-8700
RAM: 8GB G Skill
https://linustechtips.com/topic/942978-ethernet-to-pc-problem/#findComment-11491188
