Hello.
I have an Rx 480 GPU for a year now, and I have not seen this problem before, and its really weird.
When I start the GPU intensive game, particullary Rust, I have like average 27-36 FPS on average on medium settings.
When I start the Windows 10 Task Manager it jumps straight from 36 fps to like 90+. I don't know what is causing this problem, but its getting weird.
Litelary only thing I did was open Task manager. Nothing else.
And after like 5-6 minutes, Task manager shuts its self off, and I am back in mid 30 fps.
P.S. I have uninstalled all Gpu Drivers with ddu, Installed fresh one, Flashed my BIOS, and I am still getting this problem.
I have checked Thermals, they shouldn't be a problem. Only thing I do is Run Task manager. nothing more, nothing less.
https://linustechtips.com/topic/942584-rx-480-fps-issue/
which 480? Temps¿ , if its blower you should change fan speed and temperatures a bit , i had a rx480 8gb saphire blower and if i dont target temp to 80 and max temp to 70º (fuck logic) it behaves so bad with high temps , so for reference between 2100-3000 rpm its ok for blow fan and temps between 75-85(try to dont achieve 85).
Case: Corsair 760T  |  Psu: Evga  650w p2 | Cpu-Cooler : Noctua Nh-d15 | Cpu : 8600k  | Gpu: Gygabyte 1070 g1 | Ram: 2x8gb Gskill Trident-Z 3000mhz |  Mobo : Aorus GA-Z370 Gaming K3 | Storage : Ocz 120gb sata ssd , sandisk 480gb ssd , wd 1gb hdd | Keyboard : Corsair k95 rgb plat. | Mouse : Razer deathadder elite | Monitor: Dell s2417DG (1440p 165hz gsync) & a crappy hp 24' ips 1080p | Audio: Schiit stack + Akg k712pro + Blue yeti.
https://linustechtips.com/topic/942584-rx-480-fps-issue/#findComment-11487691
Malware got in somehow. I have experienced one which uses a lot of performance (probably mining) and slows everything down, but it cleverly shuts down when Task Manager starts so I cant detect it and kill it through Task Manager.
I have to reinstall the OS to resolve this...
Desktop benching:
https://linustechtips.com/topic/942584-rx-480-fps-issue/#findComment-11487704
26 minutes ago, NelizMastr said:
Is VSync disabled?
Yes it is.
I tried messing with temperatures, it does not affect preformance until I run Task Manager.
Oh for the love of God. I didn't mine with this card at all, just use it for gaming. Well, I will try to reinstall OS, even tho I really do not want to.
https://linustechtips.com/topic/942584-rx-480-fps-issue/#findComment-11487753
