A quick Google, Showed me this.
O O F
https://howtoremove.guide/how-to-uninstall-idle-buddy-virus/
Try theses steps.
M Y  S T U F F
Ryzen  PC |~|  Ryzen 5 1600 | GTX 1060 6GB | G.SKILL Ripjaws V Series 8GB DDR4 DDR4 2400 x2 |  WD Blue 250GB SSD | Barracuda Pro 2TB  EVGA 650W 80+Gold |
Laptop |~| Legion Y530 | i7-8750H | GTX 1050 Ti 4GB | 16GB DDR4 2666MHz | 128GB SSD | 1 TB Hard Disk Drive, 7200rpm |
Macbook Air |~| 2.2GHz dual-core Intel Core i7 | Intel HD Graphics 6000 | 8GB of 1600MHz  512GB SSD |
Displays |~| AOC G2460VQ6 24" x2|
Keyboard |~| Corsair Gaming K70RGB
Mouse |~| Razer Lancehead Pink RG
Audio |~| HyperX Cloud II Audio-Technica ATH-AD700X
Microphone |~| Audio Technica AT2035
M y  R e v i e w s
Lenovo Y530 Legion Laptop.
More Coming Soon...
https://linustechtips.com/topic/942374-help-idle-buddy/#findComment-11485546
O O F
Try theses steps.
yeah, but i don't want to install any other shady software. I'm trying to get rid of a virus not get more.
https://linustechtips.com/topic/942374-help-idle-buddy/#findComment-11485565
wut...
What Shady software you already have a Vrius on your computer.. From installing Shady software..
If you are talking about Spy hunter being Shady its not.
You asked, I told you the Best step.
You could also Google yourself and find a solution that would be best for you.
M Y  S T U F F
M y  R e v i e w s
More Coming Soon...
https://linustechtips.com/topic/942374-help-idle-buddy/#findComment-11485574
5 minutes ago, K i a r a said:
wut...
OK I didn't know how credible spy hunter is.
https://linustechtips.com/topic/942374-help-idle-buddy/#findComment-11485588
On 28/06/2018 at 11:41 PM, loading name... said:
recently i noticed a new program on my computer called Idle Buddy.  It will not uninstall through windows control panel or deleting the program file in windows. What is the best way to uninstall this program.
Reset your device and stop using insecure unknown open networks
https://linustechtips.com/topic/942374-help-idle-buddy/#findComment-11492748
