I NEED HELP WITH PC UPGRADES!
Go to solution Solved by GoldenLag,
5 minutes ago, 7OBEZ said:
thanks for putting these together, i really appreciate it.
is there any reason you have steered clear of intel?
usually you get better price to performance by going AMD, but it seems like new zealand is different in that regard. srry for wasting your time, i just checked Intel prices.
https://nz.pcpartpicker.com/list/PpnR4q only thing you are giving up is a slightly smaller motherboard which in most cases wont matter.
you can get an 8 core AMD build by stretching your budget. it will be better for productivity, though at the cost of worse unupgradable RAM.
it was a real surprise to me nz prices. i usually configure US and EU build.
HELP!
So i am planning to upgrade my pc in the next month or so and need desperate help with what to go with.
my first question is if i should get a i7 8700k or 7700k, if i was to go with 7800k i would need to upgrade my motherboard as well so feel free to link one of those if there is a certain one that would benefit me.(it needs to be mATX).
my second question if is should get a GTX1060 6gb or wait to see what Nvidia comes out with the 1100 / 2000 line up (please consider the wait until they come out with the new line up).
please keep in mind i am trying to find my best value for money so dont go recommending a i9 7980xe and a GTX 1080TI (insert laughing emoji here)
Thanks in advance for your help, anything is appreciated.
https://linustechtips.com/topic/941882-i-need-help-with-pc-upgrades/
1 minute ago, Some Random Member said:
What is your pc's use case?
What do you do with it?
Only gaming, or some rendering also?
i have a segotep polarlight 2.0
i will use it to develop games, play games, and render some animations / edit some videos.
Then get either the 8700k or a r7 2700x.
If you do lots of multithreaded stuff the 4 extra threads of ryzen come into play.
awesome, thanks for your help. wheat do you think i should do for a gpu? (I would rather stick with gforce)
What are you planning on doing with the pc?
intel recently released their i7 8068k with a factory set 5ghz turbo clock, BUT limited quantities...
for games and streaming a i7 6700k is still very effective if its what you plan to do, and much more available at a good price. Regarding cost efficiency probably best to get the best cpu that fits your motherboard and save $150+
as for GPU, gaming, if Nvidia base their new graphics cards on volta /turing you can bet they're gonna sell out in seconds because of the current GPU climate, and wont be very available at a good price till most likely mid 2019, but tbh thats anyone's guess
I'd look at 1070ti, they're literally the same price as a 1070 nowadays and if your looking into a 1060 its not too steep of a step up, quite a bit of future proofing as it will play most modern titles (battlefield, fortnite, pubg, overwatch etc) at 144hz or 4k depending on your settings.
hope this helps!
2 minutes ago, J1mmySl1m said:
didn't see your intended use, disregard whatever you please from above :)
hope this helps!
thanks so much, this helped alot!
Id recommend a 2700x from what ive read in this post. Also a gtx 1060 will work just fine. A 1070ti is also a good option if you have the budget to spare.
What is your budget and region? Ill create a build. What is your vurrent build aswell? (GPU, RAM, CPU)
thanks, i an in new zealand so is you are going to use pc part picker, change the country to new zealand,
i was looking to stay as close to 1000$ as possible ( within 250$ or so)
my current build is laughable....
cpu: g4560
gpu gt 710
ram 4gb ddr4 2400
mobo asrock b250m pro 4
case segotep polarlight 2.0
psu 450w
Thanks again.
cpu: g4560
gpu gt 710
ram 4gb ddr4 2400
psu 450w
Thanks again.
anything yet @GoldenLag ?
@7OBEZ
This will fit within the budget
https://nz.pcpartpicker.com/list/BdYDw6
A 6 core 1600 and a 1060.
12 GB of RAM to pair with your current single 4GB for a total 16GB. And a optionable 1TB HDD
Or
https://nz.pcpartpicker.com/list/B7qZQZ
1600, gtx 1060 with non-mismatch 16GB of ram which will allow for upgrade to 32GB in the future.
If you can get a used 1060 in your region for about 300$ you should be able to fit a 8 core 2700/x.
Its either a used 1060 or one of these, 970, R9 290x, Rx 480/580, gtx 780ti.
See if you can get them between 200-350$
15 minutes ago, GoldenLag said:
Srry for the delay. Had some stuff to do.
Gotten this far: https://nz.pcpartpicker.com/list/PwZbpG
How good is the used market over in your region?
no problem.
there arent a whole lot of second hand products going second hand that are worth buying but my local store has some gtx 1060 6gb g1 going for 460$ as a pose to 570$ so i can save abit there thats it really.
6 minutes ago, GoldenLag said:
@7OBEZ
Or
Obsoloutly no problem.
thanks you somuch for your help
Can i use that lga 1151-2 cpu in that lga 1151 mobo. Whould b good because that is the mobo i have at the moment!
for 8th gen CPUs you need 300 series mobos due to different pin layout and power delivery
