Current specs:
I5 6500 OC to 4.0ghz on all cores
16gb corsair white led vengeance ram 2x8 kit
evga 1080 ftw
asus z170 pro gaming mobo
500gb m.2 ssd
Im currently about to buy an new case, fan, and cooler
Fractal Design Meshify C - Dark TG
4x Corsair HD120 RGB LED fans
Just not sure if i should go with:
A) DEEPCOOL Gamer Storm CAPTAIN 240EX RGB
B) BeQuiet dark rock air cooler (if so which one)
https://linustechtips.com/topic/941517-need-some-help-choosing/
How about Corsair's H100i v2 or EVGA's CLC 240?
Desktop benching:
https://linustechtips.com/topic/941517-need-some-help-choosing/#findComment-11477330
12 minutes ago, narrdarr said:
EK's Predator 240 : didn't want a custom loop with limited fittings due to aluminum
EVGA's CLC 240:  i like the block more on the deepcool
does the evga clc have advantages over the deepcool clc?
EK Predator is an all-in-one cooler :P Though it is thick so that's going to the front of the case, potentially hurting airflow to the graphics card.
EVGA's CLC 240's most notable advantage is full copper construction. It also cools better than the Deepcool
https://www.kitguru.net/components/cooling/dominic-moass/deepcool-captain-120-ex-240-ex-and-360-ex-rgb-liquid-coolers-review/5/
Desktop benching:
https://linustechtips.com/topic/941517-need-some-help-choosing/#findComment-11477376
oops lol. ic.... that QD is ugly tho.... part of why im making these changes is for the sexiness that sits next me :)
8 minutes ago, ItsTheDuckAgain said:
i know its fitts the mobo, but will it clear the ram?
https://linustechtips.com/topic/941517-need-some-help-choosing/#findComment-11477395
I'm running Corsair Vengeance RAM (NON RGB) with a Noctua NH-D15 and it got about 5 mm of space between the fan and the ram. The DarkRock Pro is a little higher from the base in general so it "should" fit :-)
https://linustechtips.com/topic/941517-need-some-help-choosing/#findComment-11477406
with my low tdp chip i'd probably don't need to run both fan on it either.... giving extra room
https://linustechtips.com/topic/941517-need-some-help-choosing/#findComment-11477418
38 minutes ago, narrdarr said:
@Jurrunio what do you think of the XSPC kits?
no experience on that, I'm not a watercooling guy myself.
Desktop benching:
https://linustechtips.com/topic/941517-need-some-help-choosing/#findComment-11477492
