Basic question about a switch
Solved by chiller15,
4 minutes ago, Akalion said:Yes you didn't quite understand me. I HAVE a cable running from my router to my PC and I'm totally fine with that. I just want my old router to act as an access point to have better WiFi in my room. But to connect the old router I'd need to run a second cable to my room. Instead of connecting the AP(old router) and PC to the router with two cables, can I connect them to a switch and connect the switch to the router? So then I'd have one long cable going from the router to the switch, and two short ones going from the switch to the AP and PC.
Here I drew a little paint diagram. Would this work?
Yes it would.
